  • Guests: 31
M.A.D. (32)
12/14 M.A.D. (32)
12/15 marko666 (58)
12/16 Will T (16)
Anemometer sensor types
TheMerovingian
Mon Mar 01 2010, 12:16AM Print
For my project I built a classic cup-type anemometer with an optical reflectance sensor. Despite it construction simplicity I found many problems in making it reliable and operational.
Pros:
1)Unlimited speed of detection
2)Resolution depends on integration time and number of pulses per single rotation, making the calibration simple
3)No interation with the rotor (cogging etc)
4)Ease of design and very high immunity to noise (using hysteresis)
Cons:
1)Alignment is not trivial, and can be a very big pain...
2)Water droplets refract the IR light, causing possible problems.
3)Spurious light can blind the sensor (actually depend on the sensor shielding)
4)Too high power consumption (most of which goes to the IR led)
I know another type of speed sensing based on induced EMF on a coin (like in windmaster II anemometers) but need very careful design of the preamplification to reject noise and have a low minimum detected speed.
Are there any other type of rotation speed sensors for an application like this?
Let's discuss togheter the cons and the pros.
Mon Mar 01 2010, 01:11AM
Henry H Registered Member #2298 Joined: Sat Aug 15 2009, 08:16PM
I think some use hall effect rotary encoders.
There are also several varieties of non-cup-type anemometers, e.g. hot-wire or ultrasound.
TheMerovingian
Mon Mar 01 2010, 12:52PM
Hot wire consumes too much power and is difficult to calibrate. Maybe the hall effect can be a viable solutions, but will be difficult to achieve a reasonable resolution because it is difficult to house more than 10 small magnets on the rotor. The hall effect seems to match the low power and ease in aligning goal. Also it is simple to make it completely waterproof using resin.
Mon Mar 01 2010, 01:39PM
Some of the simplest and most reliable I've seen so far in the home-brew class use recalibrated bicycle speedometer to measure the rotational speed of the cups.
There is an ultrasonic anemometer project is in my not-too-distant future. Probably late this spring when the storm season quiets down.
-Dave
Bjørn
Mon Mar 01 2010, 02:29PM
Optical detection can be done at very low power consumption by running the LED at extremely low duty cycle and the lowest power possible.
For measuring wind speed you only need one magnet. If you need more resolution to measure turbulence you need to use a different method with no inertia anyway.
Mon Mar 01 2010, 02:47PM
Digital controlled rotation sensor
United States Patent 4195291
Ice free wind speed sensor
United States Patent D366841
ROTATIONAL SPEED SENSOR
United States Patent 3725668
worth a look perhaps
Electroholic
Mon Mar 01 2010, 04:33PM
How about this guy, 10bit per rotation, up to 10Hz or 600rpm.
Mon Mar 01 2010, 05:24PM
I agree with the comment that you don't need resolution.
The inertia of the rotating parts would swamp any resolution.
For really low power (zero) use a reed switch and rotating magnet.
De-bouncing will be required, e.g. R.C filtering.
The wire run length can be very long.
IntraWinding
Mon Mar 01 2010, 07:09PM
I used a HDD bearing, a reed switch, tiny magnet and spare cycle speedometer and calibrated it on a tall stick in a car on a still day. Probably easier just to buy one now.
TheMerovingian
Mon Mar 01 2010, 08:16PM
Bjørn wrote ...
It will be difficult to detect the reflected light and the alignment will be more difficult
Bjørn wrote ...
Sulaiman wrote ...
I need gust measuring, that's why i need high resolution X integration_time. For gust I mean brief bursts of wind (2-4 seconds) which my mechanical part is able to handle without problems (low intertia moment, since the heaviest part is the bearing and is close to the axys of rotation)
I am more and more liking the hall effect sensor/switch type. It can be very low power,easy to aligh and small magnets (5mm 2.5mm 1.5mm N42) are easy and cheap to buy (Link2). It can work even with a small coil to detect the pulses but i have to becareful in designing the amplifier stage.
THe IC is quite good, it resembles the windmaster anemometer system. Figuring out if they send samples to students...
