  • Guests: 53
seveerz (69)
10/21 ben106 (40)
10/22 803 (2025)
10/23 Iniaes (17)
Identifieng CRT pins?
dmg
Thu Feb 18 2010, 03:44AM Print
I got this cathode ray tube from my physics teacher today, It is USA navy surplus, I tried to ask him for a pin layout, he said that he didn't have one, and I couldn't find any datasheet on the internet, does anyone have this tube?
if so, what are the pin connections,
the number is JAN CRC-902-P1 (either a 1 or an I)
here is some pictures...
1266464655 2628 FT0 Vac
1266464655 2628 FT0 Vac3
1266464655 2628 FT0 Vac2
Myke
Thu Feb 18 2010, 04:38AM
You should be able to identify the heater pins fairly easily with a multimeter. If you can trace the pins from the internal structure down into the base where the pins connect, it shouldn't be too difficult to find the pinout of the CRT if you have a reference CRT with a pinout to see what the internal structures look like.
EDIT: Here's a link to the pinout. Link2
dmg
Thu Feb 18 2010, 06:09AM
thank a bunch myke, its much appritiated.
I couldn't find that anywere.
radiotech
Thu Feb 18 2010, 07:47AM
ref; Radio Amateurs Handbook 41 ed 1964.
Enjoy! By the way, why aren't you a ham ?
1266479139 2463 FT84353 Scan0015
Thu Feb 18 2010, 05:08PM
There you go. In searches, it often helps to drop US military prefixes i.e. JAN, CRC etc.
I understand that in this case, the suffix refers to the phosphor emission colour, which you'll find out when you power it up.
1266512894 543 FT84353 Crt 902
dmg
Thu Feb 18 2010, 11:13PM
thanks for all your help, I fired up the tube today, it glows green.
