  • Guests: 30
10/21 ben106 (40)
10/22 803 (2025)
10/23 Iniaes (17)
Help with comparator
Sat Feb 13 2010, 11:15PM Print
I have a 311 comparator. I connected Vc to 10v, gnd to gnd. I connected Vee to gnd.
I tried the setup with and without a pull-up resistor of 40k on pin 7, yet I could not get the comparator to work. I tried it with V- connected to ground, and then I tried it with V+ connected to ground. I tried toggling the other input to the 10v or the ground to see what would happen.
My ultimate goal is to take a floating ac signal and feed it into a comparator or a non-inverting opamp with a large gain to convert a sinusoidal wave into a clean square-wave for a PLL.
EDIT:
I seemed to make some progress. Am I suppose to have a resistor going into the V+ or V- input? I got it to work with one, and found I must have fried the other chips. I also noticed that at high frequencies the chip can not reproduce a clean square wave, and instead starts to make a ramp.
Edit:
Well, it seems I had some bad connection within the breadboard. The 311 chips were not blown. I also found that I could get a cleaner square-wave at high frequencies by dropping the value of the pull-up resistor on pin 7 to 1k. I does seem that I need some amount of resistance going to pin 2 (V+) in order to get a good square-wave; otherwise, my 50% duty wave becomes a 95% duty wave. Why is this?
Russell Haley
Sun Feb 14 2010, 04:28AM
Russell Haley Registered Member #2478 Joined: Mon Nov 23 2009, 03:24AM
It's possible that the 311 doesn't like it's inputs at Vss. You're coupling the signal in with a capacitor, right?
Try this: Connect the - input to a voltage divider to put it halfway between Vdd and gnd, and connect the + input to a high impedance divider. Couple you signal in with a capacitor at the midpoint of the second divider (same node as + input).
Sun Feb 14 2010, 06:30AM
Thanks Russell, but the problem turned out to be bad connections on the breadboard. I have gotten the 311 to work fine with the initial setup.
MinorityCarrier
Sun Feb 14 2010, 07:53AM
You need a pullup resistor on the output. Fast comparators like the 311 can go into oscillation so have a .1uf decoupling capacitor across the supply as physically close to the IC as possible.
I have worked a lot with the 311. You may wish to use a high-value feedback resistor to put some hysteresis into your circuit. Also, a 100 to 1000pF cap across the inputs can help with response/minimize output oscillation.
Sun Feb 14 2010, 11:20PM
MinorityCarrier wrote ...
You mean put it across V- and V+ ? How does this reduce output oscillations?
What is the quad equivalent for the 311 for a fast comparator? Is it the 339?
Sun Feb 14 2010, 11:23PM
The LM339 is a fastish quad comparator that I've used in many SSTC and power electronic projects.
Hernan
Mon Feb 15 2010, 01:35AM
Hernan Registered Member #1614 Joined: Wed Jul 30 2008, 03:08PM
Hi Iam, I've used LM393 with an output pull up resistor . the response time is 1.3us and it accepts single or dual supplies
