  • Guests: 59
PYLEMET-mk2 (36)
09/21 Bill G (65)
09/21 Overclocked (38)
09/21 Edi (32)
induction heating- current source inverter
Hernan
Fri Feb 12 2010, 12:16PM Print
Hernan Registered Member #1614 Joined: Wed Jul 30 2008, 03:08PM
Hi all,
After trying LCLR , series LCR topologies I started this thread because I want to try current source inverter with parallel resonant tank.
The problem is that using GDT to drive the H switches will arise to core saturation due to the overlaped gate driving signals .are optocouplers the only option?
later I found this paper which uses two switches connected to common ground
has somebody tried this topology?
thanks
Hernán
]class_d_csi.pdf[/file]
Fri Feb 12 2010, 02:31PM
That topology is just the Mazzilli/ZVS.
Hernan
Fri Feb 12 2010, 03:42PM
Hi Steve, the mazzilli uses a center taped transformer like push-pull or both are the same
thing? I`m confused because in the paper the transformer is not used
thanks
Fri Feb 12 2010, 03:47PM
Look in the OMG Induction Heater thread, I demonstrate an induction heater driven by a ZVS without a centre tapped work coil.
Hernan
Fri Feb 12 2010, 05:46PM
I've just looked at the thread you mention but I didn't find the schematic of your circuit
can you post it here?
I ´ve designed the logic to produce the ovelap at gate signals but I don't know how to drive the high side switch without GDT. I need to find some fast optocouplers
Fri Feb 12 2010, 10:16PM
Will these help?
Hernan
Mon Feb 15 2010, 01:22AM
thanks Iam, these are exactly what I'm looking for.;-)
I don't know if I could find some of them here.
]vishay_optocouplers.pdf[/file]
Mon Feb 15 2010, 03:17AM
If you click on the Freesamples link you can get 10 of them sent to you to try out. They even pay for the shipping!
Hernan
Mon Feb 15 2010, 04:46PM
Thanks Iam ,they've denied my request of free samples :(
fortunately I found a third option: a wide duty clycle gate drive transformer as is presented in this paper
what do you think?
thanks
Hernán
]wide_duty_cycle.pdf[/file]
