  • Guests: 23
my small DR-SSTC
raff
Wed Feb 10 2010, 12:08AM Print
raff Registered Member #2315 Joined: Tue Aug 25 2009, 02:35AM
guys,
finally made one... :)
3.2" x 8.2" AWG#34 secondary
using IRG4PF50WD IGBT
some pics...
mounting for the toploads
1265759937 2315 FT0 Img 3247
coated
1265759937 2315 FT0 Img 3253
drive electronics.. basically from EVRs minibrute, made simpler, no OCD..im running secondary feedback only
1265759937 2315 FT0 Img 3255
finally found a ferrite torroid.. dont know the AL.. 1:2:2 pri about 78uH
1265759937 2315 FT0 Img 3256
1265759804 2315 FT0 Img 3270
1265759804 2315 FT0 Img 3271
two toploads
1265759804 2315 FT0 Img 3272
almost IF NOT impossible to get CDE or WIMA pulse caps... SO....
my DIY PULSE cap.. 123nF @12Kv.. hey, IT works... construction method like the CDE caps (almost) cheesey
1265760281 2315 FT0 Img 3263
1265760281 2315 FT0 Img 3264
ADDED:
1265929816 2315 FT84002 Img 3275
1265929816 2315 FT84002 Img 3277
video: 1st light
had this been only an SSTC (take away the LC CAP), streamers are only 9" .... I LOVE DR!! but VERY VERY noisy! cheesey
Cheers! cheesey
HazzWold 1993
Sat Feb 13 2010, 12:55AM
Very nicely done! beautiful big thick streamer :)
raff
Sun Feb 14 2010, 01:54AM
Thanks Hazz smile
next will be upgrading power supply to full wave rectification + 740uF 400V filter caps... those shown above is just using halfwave rect and 330uF filter cap..
guys,
the more DC filter capacitance, the better.. right?
mmt
Sun Feb 14 2010, 01:49PM
mmt Registered Member #2333 Joined: Thu Sept 03 2009, 03:04PM
yea, sort of, that depends on power input
raff
Sun Feb 14 2010, 10:34PM
Hi mmt,
so... 1000uF is ok enough for 220Vac input (for this SMALL coil)? cheesey
mmt
Mon Feb 15 2010, 09:08PM
i thing that will be good enough wink
raff
Tue Feb 16 2010, 01:19AM
hi
now PS is fullwave rectified mains + 1140uF 400V lytics... cheesey
now I get a bit longer streamers +1.5" ... AND violent flashovers(topload to PRI) angry at higher ON time setting on the interrupter.. I guess its time do wind me a "longer" secondary..... 3.2"x18" awg#28... will keep the freq Loaded near vicinity 200KHz or so...
