  • Guests: 41
seveerz (69)
10/21 ben106 (40)
10/22 803 (2025)
10/23 Iniaes (17)
Wireless Glowers
radiotech
Sat Feb 06 2010, 07:32PM Print
Neon, argon or flourescent lamps glow in radio and electric fields. A while ago I found that on a dark night strings of LED Xmas lights flash, non contact, close to electric (livestock) fences.
(1) What sort of a simple loop can you make to light LEDs some distance from a TC and..
(2) How would you convert a standard 120 0r 240 volt LED lightbulb to glow like Tesla's wireless gas filled lamp?
There are also EL panels out there too in cheap nightlights.
dmg
Sat Feb 06 2010, 08:08PM
well, I guess that those LEDs flash near that fence, probably because the fence is energized by a high frequency solid state supply, also, if the current is low enough, the voltage doesn't really matter of the LEDs, I had a string of LEDs on a bushing of a 15KV 30MA NST, and at 60hz, I could draw an arc, the LEDs will light up and wont burn out. with a TC, the leds need to be a bit close and then they glow, I would think that your LED need to have one lead in the ground, and one lead in the air, and it will glow with the TC's field, I have held CFLs and LEDs to tesla coils before and they glow without a path to ground, so both methods will work.
radiotech
Sat Feb 06 2010, 08:57PM
The fencer dumps a 3 ufd cap charged to 400 V into primary of an iron core tranny; Its a Sure-Shock.
I was thinking more a small loop. Long ago I made a 40 foot long
, stove-pipe wire core, single layer #18, winding, connected to an audio amp. Women wearing crystal earplugs attached to a flat type phone pickup coil, got directions to wire a hugh electrical harness cable for aircraft while walking, passive pickup.
here's a scan: Editors, A Tribute to Nicola Tesla. Presented inLetters Articles, Documents Nicola Tesla Museum, Beograd, 1961
1265489864 2463 FT83807 Scan0002
