  • Guests: 35
Pyromaniac (34)
Wavetuner (76)
jeffomatic (75)
SparkLabs (36)
10/09 sbs_2010 (34)
10/09 SoundDoc (50)
10/10 Ryan Parle (44)
Dual GU81M VTTC
kilovolt
Thu Feb 04 2010, 09:36PM Print
kilovolt Registered Member #2018 Joined: Tue Mar 10 2009, 09:56AM
Dear All
I just wanted to show my latest project, a VTTC with 2 GU81M tubes.
The idea and schematic came from this site, thanks to the autor!
Whole Setup. High voltage power supply and VTTC are splitted up for better handling.
Dsc00046da
Dual-MOT power supply with some Microwave-Capacitors and a chaine of 12 Diodes with 1600V / 3A each for a total of 19.2kV @3A.
Dsc00045pk
VTTC itself with 2MHz resonator in the background, 2 filament transformers in the foreground (for each tube one toroidal heater-transformer). The heaters are connected each with a 1-Ohm-Power-Resistor for limiting the current in the first moment. After preheating the filaments these resistors are bridged with a big industrial relay. The grey doorknob capacitor is the primary capacitor (now 2x 470pF in series for a total of 235pF). The black heat sink is for the 2 470-Ohm/100W-Feedback-Resistors for the grids.
Dsc00050zh
Some sparks/arcs:
Dsc00172q
Dsc00143j
Dsc00197s
Dsc00218y
Dsc00159ea
For more information please ask or take a look to my website wink I know the pics are too big at the moment but I can't resize them immediately. don't worry, the moderators can :P I will do this as soon as possible. Thanx for your understanding.
Greets kilovolt
Experimentonomen
Fri Feb 05 2010, 11:41AM
Looks pretty good but i´d suggest you put the power supply in a box and use high voltage rated cable to prevent electric chock.
I see something that looks like an ALC60X in the background too amazed *drool*
kilovolt
Fri Feb 05 2010, 11:50AM
Thanks for your answer, HFsstc-freak wink Well seen, you're absolutely right, I've got two ALC-60X and a Melles Griot-643 Argon-Krypton-Laser and some HeNes. Gaslasers and high voltage is imho a nice combination smile The lasers are also described on my website, if you are interested.
kilovolt
Experimentonomen
Fri Feb 05 2010, 12:20PM
I love gas lasers! A dream i have is to someday get my hands on a multiline argon and a whitelight Ar/Kr.
Fri Feb 05 2010, 02:22PM
Nice hot sparks!
I start to like more current in the VTTC sparks (more A than V input), the show is quite wonderfull.
Hmmm, hot sparks
kilovolt
Fri Feb 05 2010, 07:46PM
Thanks for your answers, HFsstc-freak and vasil wink
@HFsstc-freak:
Your dreams will come true, I'm sure wink Multiline argons are not difficult to find... a good ALC-60X will do wink Argon-Krypton-Whitelight is a bit more difficult to find... but possible as well. I had a thread about mine:
@vasil:
In my opinion it doesn't matter if there is a lot of current or a lot of voltage: main thing is a lot of power smile I love these GU81 tubes wink They could do much more than this, but my variac is a bit weak sad
Love your DRSSTC vid smile Very nice indeed!
Greets kilovolt
kilovolt
Mon Feb 08 2010, 08:49PM
Some new pics with better tuning:
56870096
98037572
89459015
94378767
Greets kilovolt smile
