  • Guests: 40
seveerz (69)
10/21 ben106 (40)
10/22 803 (2025)
10/23 Iniaes (17)
Transformer question: why does this happen
Thu Feb 04 2010, 04:33AM Print
I have a 1:1 transformer. When I connect on side to the mains AC I measure the same voltage on the other side. When I connect just one end of my multimeter to the secondary I get 0v. However, when I connect the other end to earth ground I measure half of the primary voltage. I then connect an ammeter from one end of the secondary to ground and read 0 amps.
Why is there a voltage to earth ground that is half of the primary?
radiotech
Thu Feb 04 2010, 04:41AM
Primary secondary capacitance. Ammeters used to probe connected transformers on an undetermind shunt path often dont survive. If the meter has a capacity range, test all terminal combinations, including all terminals to core. Was the transformer rated for 120 VAC 60 Hz?
Thu Feb 04 2010, 05:20AM
240vac/60hz
radiotech
Thu Feb 04 2010, 05:59AM
What is the voltage to ground on H1 & H1 ? Fluke 117 that connects a resistance of some 10's of Kohms across the meter terminals to counter what they call 'phanthom' voltages.
"Low input impedance: helps prevent false readings due to ghost voltge"
