  • Guests: 39
seveerz (69)
10/21 ben106 (40)
10/22 803 (2025)
10/23 Iniaes (17)
Mystery Diffusion Pump
Turkey9
Tue Feb 02 2010, 05:16AM Print
I have a diffusion pump that won off eBay. It has roughly a 5in inner diameter. It has no marking at all indicating manufacturer or model. So my problem is how much oil to use in it and what kind? The only numbers are hand written and I assume they are some type of index from where it was used. Any insight at all will help!
1265088315 1451 FT1630 0201102211a 321569
1265088316 1451 FT1630 0201102211b 269554
-Thanks!
Hazmatt_(The Underdog)
Tue Feb 02 2010, 08:13AM
You could try to search for Balzers or Varian and see if there is a similar pump. I think your pump there is a Balzers.
Basic pump oil is Dow 704 Silicone Oil. You may need 200 cc of this stuff at a heartbreaking $1 per cc!!
Really, you shouldn't bother getting oil yet until you have your poppet valves and your manifold all ready to go. The reason being is that you may not be able to get a head made for the pump and may have to re-sell it later. So try to see if you can get a gasket for it, vacuum manifold and valves, then worry about pumpdown when you're ready.
Turkey9
Wed Feb 03 2010, 04:03AM
I have my other materials gathered so I think it's time for the oil! What would happen if I used too much or too little oil? This would only happen if I have to guess at how much I need to use.
plazmatron
Thu Feb 04 2010, 05:13PM
Too much fluid, and it probably wont pump efficiently. Same goes for too little, but you also run the risk of fluid degradation, (ie boiling dry)
Looking at other pumps via Google, I would guess you would be looking in the region of 175 to 250 ml.
There is a neon sign company that sells diff pump fluid at reasonable prices on evilBay.
Les
Turkey9
Fri Feb 05 2010, 04:58AM
Hmm... Looks like i'll try at about 200 cc depending on how much it costs.
