  • Guests: 46
seveerz (69)
10/18 seveerz (69)
10/21 ben106 (40)
10/22 803 (2025)
Inverter transformer question
Cypriotica
Sat Jan 30 2010, 08:32PM Print
Cypriotica Registered Member #1811 Joined: Sat Nov 15 2008, 11:52AM
Hello guys, I have been given an inverter to fix for a friend. Its a 500W TOHDA inverter. I know they are a pain t fix but im having a go. It stopped working randomly while connected to a new and charged battery with a 150W load on and apparently it was not even hot when it failed. Its blowing fuses when connected to a 12v supply.
I checked its mosfets diodes etc to see they are working... Im not really expecting an answer for all this but i decided to check the transformers (it has 2) i desoldered one and im measuring it. The outputs or such they may be are short circuits(when i subtract the 0.6 ohms of my multimeter leads) and the input is 1.5ohms (say 1 ohm if i minus the leads) Is there something wrong here or am i just a newb? Thanks for any help guys
1264883560 1811 FT0 Transformer
Sat Jan 30 2010, 08:46PM
This is to be expected, a transformer is just several coils of wire wrapped around some kind of core--so to your ohmmeter they will appear to have a very low resistance. When the inverter drives it at a high frequiency the inductance of the transformer prevents everything from exploding.
Sun Jan 31 2010, 07:27AM
If it blows fuses on switch on then check the main switching traansistor(s) - probably short-circuit...now find what else failed - I'd replace the switcher ic and any small electrolytics nearby, check for burned resistors etc. - good luck.
Cypriotica
Sun Jan 31 2010, 12:48PM
Hmmmm thanks for your info guys.. It does not have transistiors it has 4xIRF3250 and 4xIRF740 N channel mosfets which i desoldered one of each group, checked and they are ok. Should i just order a driver IC, replace it and hope for the best? :D (unless anythings wrong with the resistors or zener diodes)
Hernan
Tue Feb 02 2010, 12:48PM
Hernan Registered Member #1614 Joined: Wed Jul 30 2008, 03:08PM
an option is to energize the control board with the 12V batt disconected then check mosfets gate waveforms ( frecuency, dead time , etc)with a oscilloscope . the 12V side could be too, may be an antiparallel diode or a capacitor.
Cypriotica
Thu Feb 04 2010, 01:45AM
I dont have an oscilloscope but il be able to use the ones at my school. Thanks for the advice.
