  • Guests: 36
seveerz (69)
10/18 seveerz (69)
10/21 ben106 (40)
10/22 803 (2025)
Camera Module
Arkin
Sat Jan 30 2010, 12:37AM Print
Arkin Registered Member #2140 Joined: Tue May 26 2009, 09:16PM
I have a camera module, and fairly sure it's this one:
The spec sheet says it is VGA/CIF output. How would i being to make this connect to the computer? Will i be able to directly connect it, for digital or monochrome analog?
The datasheet is attached.
]c3188a.pdf[/file]
Bjørn
Sat Jan 30 2010, 03:49AM
The digital data will come flying out of it at at a very high rate (25 MHz or so) so a normal PC is no good if you don't build a proper interface for it.
For the monochrome analog output you can use any of the cheap USB adapters made for the purpose.
Sat Jan 30 2010, 08:33AM
As the spec. sheet says, you can add another ic for a usb interface.
Then you will need software drivers.
You would have to compete with usb-camera manufacturers.
As above, the composite mono output will feed any (Video In) for most domestic equipment.. TV/Monitor,Digitizer...
The Y outputs are digitized Brightness
The UV output contains all the color information that you could decode.
Almost certainly cheaper to buy a web-cam than to make this one useful,
unless you're into programing micro-controllers.
(Spin/Propeller probably have a five line program for it)
