  • Guests: 59
seveerz (69)
10/18 seveerz (69)
10/21 ben106 (40)
10/22 803 (2025)
Current transformer and Schmidt trigger for induction heater feedback
Mates
Fri Jan 29 2010, 02:49PM Print
Hi guys,
Is there any practical reason why not to use classical DR-SSTC primary feedback topology (employing CT and Schmidt trigger followed by pair of UCC gate drivers) for induction heaters?
GeordieBoy
Fri Jan 29 2010, 03:01PM
Current feedback from the inverter output (which is essentially what the DRSSTC topology is doing) works fine for a series resonant induction heater. It just isn't particularly flexible.
For instance you can't achieve power control by detuning the drive frequency as is normally done. An alternative technique like a controlled rectifier, burst fire of the RF drive, or a variac must be used instead.
It also results in the tank circuit being driven at a frequency just below it's natural resonant frequency so there can be some problems with body-diode reverse-recovery transients, particularly if MOSFETs are used.
-Richie,
Mates
Fri Jan 29 2010, 04:57PM
Thanks Richie,
I have more questions…
According to your comment it seems is it suitable solution only for series resonant circuit. Why? What if I use parallel resonant circuit and a matched choke in series?
Tonskulus
Sat Jan 30 2010, 02:34PM
Tonskulus Registered Member #1223 Joined: Thu Jan 10 2008, 04:32PM
There are many CT + schmitt trigger operated PARALLEL RESONANT induction heaters made. Including my ind.heater..:)
Well actually that schmitt trigger is operating as relaxant oscillator to keep it going and to start oscillation. As soon as tank circuit activates, CT signal will override relaxant oscillation and frequency locked operation is acchieved.
Try searching thread named "OMG induction heater for more info".
