  • Guests: 51
Will T (16)
william L (29)
Tipiment (62)
12/17 Ben7 (29)
12/18 Skywarrior (52)
12/18 Dark Horse (54)
PWM calculation
Fri Jan 29 2010, 01:24PM Print
The frequency of the pulse wave is 490hz
How do I determine the right R and C values so, so a low-pass filter yields a 25% duty = 0.25 of Vmax and a 50% duty = 0.5 of Vmax?
Does the RC time constant equal less than 1/5th of 490hz, or something to this effect?
Fri Jan 29 2010, 02:04PM
IamSmooth wrote ...
The average voltage will always obey the law you gave above, so you can't calculate the required RC time constant from that law. The RC time constant just affects the amount of ripple on the voltage. Generally you want it as long as possible.
