  • Guests: 43
Cprossu (40)
Kokamo (46)
GalliumMan (60)
12/30 Alex_FX (45)
12/30 Pieznice29 (31)
12/31 Arjan EMM (52)
Electro-pneumatic coil gun
SamS
Thu Jan 28 2010, 10:47PM Print
SamS Registered Member #1953 Joined: Mon Feb 02 2009, 09:23PM
Hello. Here’s a slightly different design. The basic working principle is same as in a conventional air gun except the air compressing piston is driven electrically. I saw some older threads about this kind of gun but couldn’t find anything constructed so here’s a crude prototype.
The solenoid is a 6V starter solenoid powered by two 12V sealed lead acid batteries in series. Measured muzzle velocity for nicely fitting diodes and capacitors was 11-18 m/s. I think this is still quite nice performance considering the very suboptimal design of this thing. What do you think? It could be refined for a nice rapid fire peashooter at least.
1264718841 1953 FT0 Cg6
]cg1.wmv[/file]
Xyth
Sat Jan 30 2010, 07:09PM
Xyth Registered Member #285 Joined: Mon Mar 06 2006, 02:37AM
Reminds me of the mechanism used to drive automatic air-soft guns.
Would it be more efficient to, instead of just actuating the plunger with a rod through the center of the solenoid, add a piece of pipe around the coil that is also attached to the plunger? I imagine that this would allow the magnetic field that occurs around the coil to also be utilized. I made an (admittedly shoddy) image to try and clarify what I'm saying.
1264878578 285 FT83371 Cg
SamS
Mon Feb 01 2010, 06:20PM
Did a bit of research. Internet claims that typical air rifle mainspring has a force of 600-800N. Then went to look for a matching solenoid. Found one 24V model with a force over 800N along a 50mm stroke. Only problem is that the solenoid weights a happy 15 kgs. But I guess common air rifle performance could be achieved. Don't know how big highvoltage capacitor setup would be needed for that kind of force.
Mon Feb 08 2010, 06:26PM
Force * distance equals energy. With all the losses I'd say the whole thing would need a rather large capacitor.
