  • Guests: 37
Madgyver (40)
mike0t4ever (43)
Ken M. (40)
tesla500 (39)
Fabi (32)
hatto018 (40)
10/18 seveerz (69)
10/21 ben106 (40)
10/22 803 (2025)
MOV or Disk capacitor?
dmg
Wed Jan 27 2010, 03:17AM Print
I have a bunch of collorfull little disks with 2 leads, some of them are defenitly capacitors (says the rating and capacitance) but others are not so clear, they are different sizes, collors and thickness, and I suspect some of them are MOVs, does anyone here know how to tell the difference?
Wed Jan 27 2010, 04:10AM
Oh, sometimes there are TVS's in they same package and the PTC for a TV or monitors degauss can be in the same package. that does not help, but still :P.
I wish there was a way to figure the difference out, too. Sometimes i see my Ka rated MOVs and think hey, i did not know i have nice big ceramics! Hehe cheesey
radiotech
Wed Jan 27 2010, 04:16AM
If you changed the query to: How can a device be tested to see if it behaves like a MOV, the answer would be clear.
dmg
Wed Jan 27 2010, 04:49AM
well thats the problem, I dont know how to test them, checking for continiuty is useless, capacitors (if arent internally shorted will not have any) and MOVs will not be displaying continuity either, and I dont want to apply voltage to the devices, because lets say I apply 1000V to a disk capacitor, it will be charged, but what if the "disk capacitor" is really a MOV, then I guess I just wrecked overvolted a MOV (mine that I do know have 240-400V ratings and I know for sure they are MOVs), so what I am looking for is a method to test them without damaging them.
radiotech
Wed Jan 27 2010, 06:04AM
My way would be to get a variable DC powersupply , say 0-1000 volts
and connect a resistor in series, say 50 K, 10 watt Then plot the voltage across the MOV on a graph paper as you raised the voltage.
Plot it against the current. A MOV recovers after absorbing small amounts energy.
It was a voltage dependant resistor the graph would not be a straight line. I you broke one of them in half to see what was between the plates; the ones I've seen are sort of a grainy grey
and ceramics are more white
But after you decided it was a MOV, what next ? What could you trust it to do? Perhaps they are tested with cheesecloth for UL approval.
look at thse specs Link2
dmg
Wed Jan 27 2010, 06:38AM
thanks radiotech, I have some of those part numbers, as for what I will do with them: I will use 2 MOVs in series with the center grounded in a line filter or ill use it connected live 120v to ground as a surge arrestor.
its just that I wanted to be sure that it was a MOV so I dont stick a capacitor there in its stead.
doctor electrons
Wed Jan 27 2010, 10:43PM
The easiest way to tell them apart is to use a multimeter that reads capacitance.
An MOV will not read and a capacitor will.
