  • Guests: 55
seveerz (69)
10/18 seveerz (69)
10/21 ben106 (40)
10/22 803 (2025)
IGBTs (and other power devices) and their packaging cases
Mon Jan 25 2010, 02:36AM Print
While searching for an IGBT I have noticed many different packaging cases. Many of them look similar. I am referring to the 3 lead through-hole styles.
Are any particularly better for heat transfer to a sink?
How about this one? Link2
teravolt
Mon Jan 25 2010, 04:46AM
try this one, I found fred diodes to work well
Electroholic
Mon Jan 25 2010, 05:23AM
just look up the datasheet for thermal resistance, degree C per Watt.
The one you linked is a TO 264, slighter bigger than the TO 247, but the screw hole is way off on the top. Better use a clamp for it instead of just screwing it in.
There is also a Super 247, with no hole.
