  • Guests: 34
seveerz (69)
10/21 ben106 (40)
10/22 803 (2025)
10/23 Iniaes (17)
DOA LifePO4 18650s?
Fri Jan 22 2010, 09:37PM Print
Hi all.
Just received a bag of Lifepo4 cells from a certain online retailer. (eventually) koff D*******e /koff)
Noticed a nasty chemical smell when opening the bag and localised it to two of the cell packs.
Upon examining several cells they seem to be "leaking" a browny-black gel from around the vent which is concerning.
Many of those when tested were well below MSV at around 1.8 to 2.2V or so but some of the clean cells also do.
70% or so test to 3.22 V and look OK.
reckon these are bad?
have contacted them in HK but so far nothing :(
am wary of using any of them until i have tested every single one now, in case they are defective/fakes/etc.
regards, -A
aonomus
Fri Jan 22 2010, 10:05PM
Its dealextreme, no surprise there.
I bought 4 of these cells and did some tests:
Discharge profile
LiFePO4 Discharge
Charge profile
LiFePO4 Charge
You can see that they aren't really 'up to snuff' LiFePO4s.
[Edit: Monster Mega Pictures]
Fri Jan 22 2010, 10:08PM
AAAUGGGH! I've been scammed!!! :( :(
any ideas? have filed a Paypal dispute "defective/not as expected"
are any of the cells likely to work or are they totally useless?
regards, -A
EEYORE
Fri Jan 22 2010, 10:33PM
That place is nothing but junk. I would escalate your paypal dispute to a claim right now. I do ALOT of business with paypal, so I can tell you that you need to ecalate to a claim (not dispute) right now and get ready to send that junk back.
Matt
Sat Jan 23 2010, 01:03AM
Status
We're unable to decide this claim in your favour at this time. Ps Buyer Complaint Policy applies to the delivery of goods but not to disputes about merchandise quality.
now what do i do?
Carbon_Rod
Sat Jan 23 2010, 01:35AM
Contact the seller >after< PayPal...
as sellers tend to use stall tactics to pull a scam after the claim period expires...
DX likely uses the slowest shipper available to decrease its refund rate.
Then voice your situation on the vendor's forums with photos if no response.
Usually, LiPol safety vents rupture because the cells' overheated from shorts, punctures, or stress.
Cheers,
