  • Guests: 53
01/18 Noelle (43)
01/18 King_of_Junk (36)
01/18 Ixz (35)
PSU and Marx Impulse Generator advise
Zeus
Wed Jan 20 2010, 01:40AM Print
Zeus Registered Member #2316 Joined: Tue Aug 25 2009, 03:04AM
I have a 10 to 20000Hz driver in mind, it is a IGBT driven by a signal generator program and an amplifier.
The computer will be isolated with four metres of fiber-optic cable and so on. I haven't found any
flaws yet so I hope you can help. Also I have read about Marx Impulse Generators that use
1k resistors. They have a very sharp rise time (I think). Any help would be great.
Regards
Lachlan
Wed Jan 20 2010, 02:42AM
Is your fiberoptic cable driven by pulsing DC or is it a sine AC type audio generator?
-Patrick
Zeus
Wed Jan 20 2010, 06:48AM
I am not sure, Iwas intending to adapt an IR LED and phototransistor to it.
Wed Jan 20 2010, 08:30AM
Yikes! you better be sure before building the rest of it!
Are you using and audio generator type program? If so you mabe better off with a 555 timer or some such time base generator.
Tell me waht program you are using and maybe I can advise you. Did you get it from download.com?
-Patrick
Zeus
Wed Jan 20 2010, 10:17AM
I've had no luck with the 555 before. I have a fibre-optics experimenter's kit I can use
the adapters from it. I will post the link for it.
Wed Jan 20 2010, 02:00PM
The 555 is highly reliable and adaptable, if you cant get it to work, you're dong something wrong.
-Patrick
Th3_uN1Qu3
Wed Jan 20 2010, 10:08PM
Th3_uN1Qu3 Registered Member #2614 Joined: Sat Jan 09 2010, 08:57AM
Patrick wrote ...
-Patrick
True that, i have built a strobe running on rectified mains, using a 555 powered from a voltage divider and a power mosfet, worked just fine on regular incandescent bulbs. When i tried a 500W halogen bulb with it, the fet instantly blew (i'm suspecting too high surge current), but on inspection the 555 was still alive.
Zeus
Thu Jan 21 2010, 02:34AM
I like the computer program because it has several waveforms. I can get a 555 based kit with runs between 100 and 20000Hz which can be modded to 40000Hz. I might look into that after the centre vic hamfest.
