  • Guests: 28
Reaching (40)
ryanshow (38)
07/22 Reaching (40)
07/22 ryanshow (38)
07/23 Will (38)
Slow FETs?
ScotchTapeLord
Sat Jan 16 2010, 02:34AM Print
After working on a full-bridge power supply for a shamefully long time, I believe I've isolated my transistors as the issue. When power is applied, my system is a dead short. I've moved to a half-bridge design for the sake of my limited silicon supply. After many interesting failures (from exploding pcb traces to a pinhole-size explosion through the casing strong enough to blast through a heatsink clip!), I decided to test what I had. I've exhausted my supply of IRFP240's, and am left with the stronger IRFP460's and some IRF740's. I want to run my system from 350-400kHz, which I know the 740's should be able to do. But after finding my system was yet again, an effective short (this time, ballasting it with a 1k resistor, and running from a battery...) I decided to test the FETs individually. I did this by attaching one to my GDT signal (which is quite clean) and then used my trusty 1k resistor as a load. I tested the waveform across the resistor and FET and found terrible waveforms even in the 200kHz region. They would not even turn off as I got closer to 400kHz.
What do you guys think is going on? Am I the biggest sucker for EBAY FET counterfeiters? Is it possible that my o'scope is wrong about the frequency? Is my means of testing off?
Thanks!
Sat Jan 16 2010, 09:45AM
its possible the devices are counterfeit, the only way to tell for sure is order them from rapid or farnell.
giveaways:- the writing looks "fuzzy" or off centre, and usually counterfeits will feel lighter than the genuine article.
