  • Guests: 54
davovinch (75)
Duncan (37)
Vatorius (60)
waicool20 (27)
12/11 Forty (38)
12/13 williamn (48)
12/13 ReddyK (57)
Searching for an equivalent geiger tube to a PHILIPS ZP1400
Andrew L.
Tue Jan 12 2010, 10:30PM Print
Andrew L. Registered Member #515 Joined: Sun Feb 11 2007, 02:06PM
As the title says I am searching for an equivalent tube.
Does anyone know if there is an equivalent tube to this one ?
Best regards
Wed Jan 13 2010, 12:57PM
Mullard: MX147
TGM: N205
Philips/Amperex: 18504
LND: 7124
As you would expect, there are small differences between these end-window tubes and the claims made for them. For example, the Centronics ZP1400 is described as a beta/gamma tube, whilst LND's 7124 claims to be an alpha detector as well, though the areal density of the mica window is cited as between 2 & 3 mg/cm2 in both cases.
Andrew L.
Wed Jan 13 2010, 09:27PM
Cool thank you. Do you know where could I get any of these tubes, because eBay doesn't turn out any results?
Thu Jan 14 2010, 12:44AM
LND Inc is here:
Centronic, which took over the entire Philips GM tube business in 1992, is here:
