  • Guests: 86
Thomas (40)
VulcanBB18 (50)
07/20 rev (49)
07/20 Cheech707 (35)
07/20 M_Gargantua (35)
plans for making a induction cooker?
haxor5354
Tue Jan 05 2010, 05:26PM Print
I wanted to make a induction cooker that atlease warms food in a metal plate/bowl. I've made iduction metal piece heaters with the ZVS flyback driver before. heats up a nail to glowing red hot in a few seconds if ran at 24V. So if I want to make the induction coil by my self, how long would the copper wire have to be? and atleast what gauge size does it has to be? Also, i need some ideas on what to use for the heat insulator, so the coil stays cool while cooking.
Tonskulus
Tue Jan 05 2010, 09:28PM
Tonskulus Registered Member #1223 Joined: Thu Jan 10 2008, 04:32PM
Flat spiral coil, maybe 6mm2 insulated litz wire or similar. 30..40turns maybe.
Then you need somekind of high frequency power source, few hundred watts at least. Well made mazzilli ZVS can be converted for this purpose I think, using dual flat spiral coil.
haxor5354
Wed Jan 06 2010, 04:03AM
would it work if I use the wires that are for house wirings? connect 1 end of the ends together to make a center tab and then make the whole thing into a spiral shape
1262750597 2063 FT82074 Induction Coil
Tonskulus
Wed Jan 06 2010, 08:13AM
haxor5354 wrote ...
That connection doesnt work. You must connect it this way:
1262765635 1223 FT82074 Wiring
GeordieBoy
Wed Jan 06 2010, 03:18PM
A mult-turn flat coil made of litz wire will work well. Yes, it has to be litz otherwise it will heat up rapidly with the HF currents flowing due to skin effect. You also need to include a thermal insulator between the coil and the surface of the pan being heated, otherwise the coil will be damaged by heat from the workpiece.
A picture of a typical cooking coil can be seen here:
These app notes give some info about Induction cooking hobs and rice cookers...
There are a few errors in the first paper though!
-Richie,
haxor5354
Wed Jan 06 2010, 10:19PM
will I be able to find litz wire in high frequency switching transformers?
Tonskulus
Thu Jan 07 2010, 02:21PM
haxor5354 wrote ...
Yes, but not long enough at all..
Adrenaline
Thu Jan 07 2010, 02:48PM
Adrenaline Registered Member #235 Joined: Wed Feb 22 2006, 04:59PM
I found quite a bit of litz wire wrapped in the deflection choke of a 21" Trinitron CRT monitor.
haxor5354
Fri Jan 08 2010, 02:09AM
i ripped out 2 large switching transformers from a projection TV. they're around 2 inches in lengh for each 1. will that be enough?
1262916581 2063 FT82074 010710210425
GeordieBoy
Fri Jan 08 2010, 01:01PM
Compare dimensions of ferrite switching transformers with induction heating coil in the picture I linked to.
Looks like a lot more wire in the IH coil to me.
