  • Guests: 29
Reaching (40)
ryanshow (38)
07/22 Reaching (40)
07/22 ryanshow (38)
07/23 Will (38)
Ideas for wireless shoe heater
Mates
Fri Jan 01 2010, 11:37PM Print
Hi guys,
I do a lot of winter biking (downhill in the snow on a good mounting bike is much better than skiing and snowboarding) and I’d like to discuss a problem which all the winter bikers have and which might have some solution.
The problem is that no matter how good is your cloth your feet will always suffer from cold. This has physiological reason and more or warmer socks cannot solve the problem. So I came with an idea which would be some kind of electric heater placed inside the shoe as part of the inner sole. However, there is problem how to connect the heater with a power source. I’d like to avoid cables if possible and came with this idea:
You all probably know the stupid little mobile phones accessories (stickers and small toys) working as a small antenna stealing some of the RF energy and giving some diode flashes. What if the whole inner sole would be designed as a big dipole antenna collecting RF energy from a source which would be placed close to the shoe? (e.g. fixed on the leg - maximum distance 20cm) Any chance for energy transfer which would be practical in such setup? Remember there is no need for large amount of watts going into the shoe. It is well insulated so I think even 1W of heat could be enough. Is this realistic project?
Sat Jan 02 2010, 12:12AM
That seems entirely reasonable, if you have a pair of shoes that have a integral steel stiffening plate (or add some steel plate of your own) you could just set it near an induction heater with a pancake coil (like the inductive stoves).
haxor5354
Sat Jan 02 2010, 02:18AM
... wrote ...
then drive the coil with a minature ZVS driver wink
radiotech
Sat Jan 02 2010, 02:50AM
there are ways to generate the energy while the bike moves. Hack a toothbrush charger for a way to move it to your foot. A nice translator is a shake chargeable flaslhight.
wylie
Sat Jan 02 2010, 11:24PM
wylie Registered Member #882 Joined: Sat Jul 07 2007, 04:32AM
How about those shoes that lock into the pedals? Could just conduct power from a battery mounted on the bike into your shoe. Not sure about how to setup the return path to the battery without an example pedal/shoe combination in front of me though.
Wouldn't it'd be simpler and more efficient than any RF heating/power-xfer schemes?
Turkey9
Sun Jan 03 2010, 01:18AM
Put a small rf transmitter in the pedal with an antenna in your shoe connected to the heating element. Then tune it to resonance! Similar to those wireless cell phone chargers that are coming out on the market.
Avalanche
Sun Jan 03 2010, 12:42PM
am I the only one thinking this would be nearly impossible? Any induction heating of your 'foot' would also heat the pedal...? I also think you'd need a lot more than 1 watt, maybe 25 watts - not including losses!
I think realistically you'd need to use a wired system, similar to heated grips for motorbikes. Run it from a frame mounted battery, a similar arrangement that those old halogen bike lights used.
Myke
Sun Jan 03 2010, 04:51PM
No, you aren't the only one. I was also thinking that you would need a lot of power to heat up the plate and also that induction heating would be pretty inefficient. There are a lot more losses compared to just some heating element because of the loose coupling and such.
You would be better off going with a resistive element.
The wireless phone chargers aren't working with enough power to heat up a plate noticeably. They are working with just enough power to charge a little li-ion battery.
Sun Jan 03 2010, 05:51PM
Maplin's heated insoles Link2 work off three AA batteries that probably strap to your ankle. If that isn't high tech enough, you could use lithium-ion.
Do we have any hard data on how many watts of heat human feet give off?
kell
Mon Jan 04 2010, 12:41AM
kell Registered Member #142 Joined: Sat Feb 11 2006, 01:19PM
I thought the 25 watt figure somebody threw out was way too high. Imagine putting a 25 watt bulb inside your sock -- it would burn you.
According to this site
the entire human body only puts out about 95 watts of infrared heat.
Surely a very small fraction of that would keep your feet warm, unless you have wet socks sucking away the heat. One of the tricks used by bike messengers (I speak from experience as a former NYC messenger) in winter is to put plastic bags over your socks, inside your shoes. Your shoes will get wet but not your socks. Keeping your socks dry and inputting just a few watts by way of a DRY electric insole (inside the plastic bag) might do the trick.
