  • Guests: 33
seveerz (69)
10/18 seveerz (69)
10/21 ben106 (40)
10/22 803 (2025)
Audio
cduma
Tue Dec 29 2009, 07:58PM Print
I have an amplifier with one output and several inputs. PS3, PC, Stereo etc. The PS3 channel in particular is too loud and the pre-amp in the PC cant compete with it. Would it be as simple as adding a resistor to the PS3 input to lower the volume?
Tue Dec 29 2009, 09:13PM
Yes.
Better may be a 10 kOhm potentiometer for each channel to allow easy setting.
cduma
Wed Dec 30 2009, 12:00AM
Great! Nearly everytime I try to use an op-amp something goes wrong. Isnt 10k more than a little high? I am pretty that the V is less than 24V since I cant feel it. Wouldnt a multi turn 100 ohm pot be best?
Wed Dec 30 2009, 01:10AM
For audio outputs meant to drive speakers or headphones directly,
a 100 Ohm pot would be fine,
multi-turn is not required since +/- 10% will make very little difference.
A 10k pot should be ok with most audio sources.
Be sure to wire it as a potentiometer
- one end to shields/earth/0v, other end to source, wiper to amplifier.
Not as a variable resistor in series.
Bjørn
Sulaiman really knows what he is talking about so try 10 kOhm, it will work if it is anything close to a normal sound signal.
Connect it like this: Link2
[Now you got it twice for the same price!]
cduma
Wed Dec 30 2009, 02:33AM
Cool! Thanks guys! The signal is not meant to drive speakers. I am pretty sure that it is digital. It wont make any difference though. I think that the volume is still controlled by amplitude
