  • Guests: 36
Reaching (40)
ryanshow (38)
07/22 Reaching (40)
07/22 ryanshow (38)
07/23 Will (38)
Just wanted to show my Induction Heater in action
1 2 3 4
Mon Dec 28 2009, 03:15AM Print
Well, I got it off on its first near full power run.
Melted a steel nut. It is a PLL/integrator feedback design.
teravolt
Mon Dec 28 2009, 07:08AM
very cool IamSmooth, what type of caps did you use and do you have a picture of your aperatus? how much power do you have to consume to fuse the bolt and washer?
Tonskulus
Mon Dec 28 2009, 09:00AM
Tonskulus Registered Member #1223 Joined: Thu Jan 10 2008, 04:32PM
Good work there!:) Is it using 4046 or what?
Mon Dec 28 2009, 12:31PM
I am working on a web diary that will document the whole thing. I will post the link when it is complete. I am still playing with altering certain variables, like the turns on the coupling transformer and the material.
The input was 90-100v @20A. The caps are high power metallized polypropelene snubbers from Illinois Capacitor. There are 20 rated at 14A/3000vdc/850vac. The inverter uses the HEF4046 with the PCA1 output going through an integrator. I have a trim on the V+ limb of the integrator in order to fine tune the tracking if necessary. I found it tracked resonance better than the simple low-pass RC filter.
Mon Dec 28 2009, 12:41PM
Good work, Jonathan! Do you plan on implementing current/voltage limiting?
GeordieBoy
Mon Dec 28 2009, 12:49PM
Well done! 2kW is quite a lot of power for a half-bridge. Particularly when running from only 110V mains supply!
What switching devices are you using?
-Richie,
Mon Dec 28 2009, 01:28PM
I have a 20A/120v variac that I use to control the input voltage while monitoring the current. I never made it to full voltage.
The mosfets are here: Link2
When designing it I made sure the inverter voltage and current were in phase. The water cooling is a must as well as some large heat sinks on the mosfets. With all this the inverter and tank stay completely cool. All the signals are very clean. Again, I will have the schematics and pictures posted soon. I am glad you guys all like it.
Can any of you tell me where I can get a crucible that can withstand molten steel? I saw Kimlaha use some asbestos-looking container and cover in his video. If I can contain the radiating heat I should be able to make a molten bath of metal in a few minutes.
Experimentonomen
Mon Dec 28 2009, 06:07PM
You can make a crucible outta the same stuff they line the inside of induction melters with.
Another choice is graphite but then the induction heater would only heat the crucible and not the metal charge itself.
teravolt
Mon Dec 28 2009, 06:44PM
hi Jonathan, what is the value of each capacitor and the tank frequency. At some point I would like to build this project and I am looking for some low ESR caps that won't get hot. I was thinking couldn't a crusible be made from plaster peris. they must make a comershall crucibal made from firebrick.
Sat Jan 02 2010, 03:37AM
I just wanted to let everyone know that I put together a web tutorial on my project so those just starting this can see what is going on and how it is done. I have posted my schematics and numerous oscilloscope tracings to make it easier to understand. When I started this I knew nothing of inverters, let alone induction heaters, but I thought it would be a cool (funny, huh? I should say hot!) to try this. I had some issues understanding how the circuit was achieving the goal of heating metal, and I had no clue about PLLs.
If you to this tutorial you should have a great reference, plus the schematics to a high power induction heater. If I got something wrong, or something is not clear you can PM me so I can make corrections or additions.
