  • Guests: 60
RickR (18)
TheBoozer (58)
invader (50)
TheAncients (32)
01/10 Hanzie (31)
01/10 badger (52)
01/10 h3X (40)
Very easy HV power transformer
Fusion
Fri Apr 21 2006, 07:19PM Print
Fusion Registered Member #354 Joined: Thu Mar 30 2006, 10:12AM
Can this design work?
1145647158 354 FT0 Dibujo
Self Defenestrate
Fri Apr 21 2006, 07:56PM
Self Defenestrate Registered Member #87 Joined: Thu Feb 09 2006, 01:36PM
If your using 6v-220v why would you need sixty of the transformers? If you have 220v mains, the you would need forty of the transformers to handle the voltage, resulting in ~8kv. I don't know how the transformers would hold up being pushed like that. It would work, but not for too long.
Fusion
Fri Apr 21 2006, 08:13PM
Yes, you are true it is a typing error. But I have done calculations and between upper stage and its primary would be 8kV-220V=8kV, so I think trafos would be toasted frown
Marko
Fri Apr 21 2006, 08:52PM
Cores would have to be ungrounded wich is dangerous, maybe it would be best with all-under-oil.
I you ever come to such a number of small transformers you can always try it.
Fri Apr 21 2006, 09:07PM
Yeah, but the primary windings are still connected to 220V, which is basically 0V as Fusion already realized:
Anyway, i dont think you could do much more than maybe 2-3kV this way, but it really depends on how the transformers are constructed.
Marko
Fri Apr 21 2006, 09:28PM
Exactly, if primary is wound over secondary you would have spot for easy breakdown.
You would have to seek for transformers with thickest possible plastic former and separated prmary/secondary windings,
GimpyJoe
Fri Apr 21 2006, 09:31PM
You would have to ballast this. The 6v side of the transformer doesn't have enough inductance. I have fried a number of 12v-120v transformers this way.
