  • Guests: 48
Inverter Microwave Transformer
Self Defenestrate
Sat Apr 22 2006, 08:47PM Print
Self Defenestrate Registered Member #87 Joined: Thu Feb 09 2006, 01:36PM
I just picked up a dead inverter microwave for ripping, and wondered what the general consensus for driving the ferrite cored mot would be. It has a CW cascade built onto the pcb, and some big igbt's heat sinked too. The mot has a litz wire secondary showing for the filament, and plenty of core exposed for winding a primary. So, ZVS, half-bridge, 555 igbt driver, what do you think?
Electroholic
Sat Apr 22 2006, 09:27PM
Not sure what you are asking,
but if you want me to choose from ZVS/halfbridge/555+igbt
I will go for ZVS,
quick and simple, yet efficient and robust.
Hazmatt_(The Underdog)
Sat Apr 22 2006, 10:13PM
why not repair the broken driver? That's what I would do. Besides that, its all boarded out for you, efficient, self tracking and controlled, why reinvent the wheel?!
Sun Apr 23 2006, 12:29AM
becuase it would be easier to just make the zvs... I think you have just about everything you need there...
Unfortunantly the fact that it isn't working probably means that on or both of the fets are dead, so...
Self Defenestrate
Sun Apr 23 2006, 04:17AM
It wasn't until everything was desoldered and bent that I noticed the fuse was blown. Doh! I had already tried running the driver already built into the microwave, but it wouldn't work, most likely because there was some sort of enable switch in the door that got ripped out. I'll have a pic of the transformer soon.
Marko
Sun Apr 23 2006, 12:36PM
I would give it a halfbridge, maybe of that same IGBT's from inside if they still work (i'm also interested about their designations). Run it at highest possible frequency with relatively small primary and you can get some serious opwer out of that transformer, and get to several kilovolts with enormous current.
Power can get up to about 2kW, maybe you could rectify it and power a DC SGTC with it.
