  • Guests: 43
120v variac run on 240v?
Aussienitro
Fri Dec 25 2009, 07:21PM Print
Aussienitro Registered Member #2399 Joined: Mon Sept 28 2009, 09:29AM
Hello.
What would be the outcome of running a 120v input 0-130v output variac on 240v mains power from a wall socket?
I for the life of me cant find a 240v variac at less then $1000, but picked up a 120v one for $15.
Fri Dec 25 2009, 08:07PM
It would very rapidly heat up and destroy itself, if the fuse doesn't blow first.
mikeselectricstuff
Sat Dec 26 2009, 01:30AM
The core would saturate, probably blowing the fuse. However if you had two 120v variacs you could probably use a series configuration, preferably mechanically ganged to balance load between them.
Backyard Skunkworks
Sat Dec 26 2009, 02:06AM
And I'd make sure that they are both of the same make/current rating, or at least have very similar inductance and resistance.
Sat Dec 26 2009, 04:44AM
Depending on where you get the variac, it might not be wired the way you think. I would make sure the neutral wire is really neutral and not going to the HOT terminal of your outlet. I would also make sure the neutral is not connected to the grounding wire of your chassis.
Aussienitro
Sat Dec 26 2009, 12:40PM
OK, well i guess the alternative would be stepping it down to 120, then back up to 240. Low power transformers are $1 on ebay.
But that brings up the next question :P What would happen to a 60Hz variac running at 50Hz?
Coronafix
Sat Dec 26 2009, 11:10PM
How much did you want to spend on a variable transformer. You can buy them new from Westek Electronics in Melbourne.
I'm sure you can source a local supplier if you are elsewhere.
