  • Guests: 45
davovinch (75)
Duncan (37)
Vatorius (60)
waicool20 (27)
12/11 Forty (38)
12/13 williamn (48)
12/13 ReddyK (57)
X-rays and Alu-foil
wicked alex
Wed Dec 23 2009, 05:11PM Print
wicked alex Registered Member #1786 Joined: Tue Oct 28 2008, 03:23PM
Hi, If you have a objekt warped in alu-foil, can X-rays see throw it and indendifie the objekt?
Wed Dec 23 2009, 05:36PM
Jeez, use a spell checker. Aluminum foil is neither dense nor thick, so yes, all but the lowest energy x-ray sources will see through it. If you're contemplating an x-ray machine or smuggling goods, do yourself a favor and don't.
LutzH
Thu Dec 24 2009, 08:30PM
LutzH Registered Member #1721 Joined: Sat Sept 27 2008, 08:44PM
Hello:
Aluminum is used to filter X-rays and remove the low energy soft ones. In medicine we use 1-2mm of aluminum as a filter.
So aluminum foil will not show up at all on x-ray unless it is a dense crumpled ball of it, even then it will be hard to see. You can buy lead lined pouches to protect film from airport x-rays, but they can still see what is inside, the image is just a little mottled.
So to answer your question if you wrap something in aluminum foil, only the foild will not show on the x-ray, the object inside will show up just like the foil is absent.
There is a strong metal which when made correctly does not show up on x-ray at all, even a blade made from it will not show up. I will not be the person who opens this pandora's box by posting what it is on the web.
I will just say that x-ray screening is part of the illusion of security perpetrated by the US Gov. They put on a good show to fool people into thinking that they are safe. Its all about the money, which has become our national religion: The all mighty dollar. The illusion of security gets them to fly more.
Real security requires educated people, who have to be paid real wages, doing this would be giving money to someone who is not wealthy, and that's un-American. Think about it:
If a drug mule can stick kilo's of drugs in their rear, what is going to prevent the terrorist from doing the same with C-4?
We have been safe due to "Luck" not due to security. So the next time you "Take off your shoe" think about it and notice all of the gaping holes. When I fly I look at the people, if someone or something does not look right, I take note and try to sit by them initiate a small conversation etc. If I then get the heebeeGeeBees, I will not hesitate to approach an airline representative. I have only needed to do this once, and the airline folks were very discreet,and did not hassle the person, they were however very appreciative, confiming their low confidence level in the airport security folks in the conversation.
Europe and Israel do real security, complete with highly trained screeners, and well trained mental health professionals screening ALL pasengers. When you have to do something you do not re-invent the wheel, just copy these folks for real security. The problem is that this costs money, and there are not millions of dollars going to sub-contractors,who lobbied their gov. representative for the contract. So we go on trying the square, the triangle, and the hexagon to make a wheel.
Fri Dec 25 2009, 08:39AM
purchased a "film safe" made by hama, from jessops.
will test with known sources and let you know.
(i have Th232 and Am241 as well as small xray producing rectifier if i ever manage to get it working)
Fri Dec 25 2009, 11:02AM
LutzH wrote ...
Surely, one needs to tailor the tube according to the needs of the application. I have a transmission target tube with a maximum anode potential of 15Kv at 50 uA, whose rays will be almost completely blocked by aluminium foil.
Z28Fistergod
Fri Dec 25 2009, 04:56PM
Z28Fistergod Registered Member #2040 Joined: Fri Mar 20 2009, 10:13PM
LutzH wrote ...
Yeah, but we would know something is wrong as soon as someone tries to check their mule.....unless.....oh, you said.....eeeewwwww.
Sat Dec 26 2009, 03:46AM
LutzH wrote ...
At least the triangle was an improvement over the square wheel. It eliminated one bump. smile
LutzH
Thu Dec 31 2009, 04:13AM
Hello:
Ya now with the most recent security failure I am sure we will see the hexagon!
Yes true a very soft x-ray tube like a lorentz tube will be affected by Al foil, but one layer of foil will transmit even Cu Ka x-rays. The point is when you try to image with the x-rays the inherent filtration of the film cassette, or the IT tube will absorb much more than the foil. The front of most standard x-ray cassettes is 10-50 times the thickness of foil aluminum, although new digital cassettes use graphite. So for spectro work it could a problem but for imaging, the foil is of no consequence.
