  • Guests: 57
Noelle (43)
King_of_Junk (36)
Ixz (35)
geobruce (31)
tulkas (32)
Gregory (31)
01/20 CT2 (37)
01/20 Josh Johnson (46)
01/21 Banana Man (41)
coil gun pcb design
coilgunrookie
Thu Dec 17 2009, 08:19AM Print
coilgunrookie Registered Member #2548 Joined: Thu Dec 17 2009, 08:08AM
can anyone help me? I'm trying to find a good pcb for coil gun, i'm running 30 330v 270uf capacitor's in parellel single stage, 555 timer. and i'm trying to find a fater way to charge. i need help with the whole thing. any help would be great
Thu Dec 17 2009, 02:50PM
Try using a transformer connected to the power mains. Follow that with a fullwave rectifier and current-limiting resistor. Highly reliable and very fast. It could fill your 440-joule bank in a very few seconds.
When choosing a transformer, note the square-root-of-two conversion factor between AC and DC. This is due to charging caps up to the peak voltage, while AC is specified in RMS voltage.
That is, to get 330v DC then all you need is a transformer output of (330)/(1.414) = 233v AC. Fortunately a common transformer size is 220v secondary output.
Cheers, Barry
Why do they lock gas station bathrooms? Are they afraid someone will clean them?
