  • Guests: 33
seveerz (69)
10/21 ben106 (40)
10/22 803 (2025)
10/23 Iniaes (17)
A few MOSFET's and stuff from a CRT monitor
lpfthings
Sun Dec 13 2009, 11:47AM Print
lpfthings Registered Member #1361 Joined: Thu Feb 28 2008, 10:57AM
Hi, I recently ripped a 19" CRT monitor. Had a nice flyback in it giving me 5cm or so arcs with a simple 555 driver :)
Now, I also have a few transistors/MOSFET's I pulled from the monitor. There is 2 IRF640's, and a SSP7N60A. As well as 3 BUK455's which I have found a use for.
Anyone know something I can do with these parts I have found from the monitor? Higher power flyback driver? Induction heater?
Cheers,
Dan :)
Sun Dec 13 2009, 11:59AM
You could build a Mazilli ZVS driver or a small sstc with a halfbridge, something like wards sstc5
HVLOVER!!
Thu Dec 24 2009, 03:08PM
HVLOVER!! Registered Member #2567 Joined: Wed Dec 23 2009, 11:56PM
yep what Mads Barnkob said, build the mazzilli flyback driver! it works great! but don't use the IRF640's on it, they blow up after a while. but whatever you use make sure the mosfets can handle atleast 8 amps. i built a smaller (current draw) zvs and my 640's blew up, my 740's got warm and 840's were still cold on long runs. but now i am using two 20A mosfets that i also found in a CRT Monitor. so now i am running at full power but only use those mosfets for a lower power zvs.
EDIT: you can check out my zvs driver here if you want to; Link2
