  • Guests: 45
01/18 Noelle (43)
01/18 King_of_Junk (36)
01/18 Ixz (35)
Distribution of electric charge
lhl_henrylui
Fri Dec 11 2009, 04:47AM Print
lhl_henrylui Registered Member #1498 Joined: Thu May 22 2008, 07:08AM
Why electric charge loves to go to surfaces?
Why electric charge tends to accumulate in sharp or pointed corners?
WaveRider
Fri Dec 11 2009, 08:13AM
Good fundamental questions!
1) If you have a conducting surface, charges will distribute themselves such that the energy in the electric field in the surrounding space is a minimum. (Google "principle of minimum energy"). Note that this is a fundamental physical phenomenon that applies to all physical processes and is particularly important in thermodynamics, etc.
2) The same principle applies in your second question.. The charge concentrated near the point represents the minimum energy configuration. The field intensity can become (theoretically) infinite, but the energy density is always integrable. I played with some of the mathematics a few years ago here.
Dr. Slack
Fri Dec 11 2009, 10:24AM
Whereas all that Mr Rider said was correct, it misses the anthropomorphic point about why the charge "loves" to go to surfaces and corners.
It will minimise its energy by behaving as if it "hates" its own kind, every electron strives to get as far away from the others as it can, and heads for where the electric field can be made greatest. Sort of.
Sun Dec 13 2009, 04:03PM
Gauss's Law, innit?
