  • Guests: 66
Vacuum tube flyback driver?
Coherent
Sat Dec 05 2009, 05:26PM Print
Coherent Registered Member #1886 Joined: Sun Dec 28 2008, 02:55AM
I'm just wondering if anyone here has actually attempted one and if it worked well. I figure it must be possible because the old tube tv's had to drive the flyback somehow.
Sat Dec 05 2009, 07:04PM
The page is in Czech, but I hope the schematic is understandable smile
Edit: Translation of the schematic notes-
The transformer has an air gap in the core.
Everything needs to be properly insulated, it is possible to over 3kV to appear on the anode.
And an important note from the text, the intrawinding primary and primary-feedback insulations must be able to hold off a few kilovolts.
We use decimal comma instead of decimal point.
Sat Dec 05 2009, 08:16PM
I was going to suggest using line output valves (US: sweep tubes) like PL509, which enjoyed a brief popularity in compact linear HF amplifiers some years ago, and would be much easier to use for someone unfamiliar with thyratrons.
The second link above is considered to be 'suspicious' by zone alarm so I didn't look at it.
Sat Dec 05 2009, 08:38PM
OK here is a direct link to the schematic if anyone is having problems with my site: Link2
plazmatron
Sun Dec 06 2009, 02:10AM
Steve Connor did this with an EL-34 to drive a plasma globe:
here
Les
Coherent
Mon Dec 07 2009, 05:34PM
Dr. Kilovolt wrote ...
amazed
Very nice arcs from that thing. Thanks for the answer to my question.
radiotech
Fri Jan 01 2010, 01:44AM
On the schematic the empty socket DC anode and screen voltage will be about 1300, and 650 respectively. Valves driven to pecular modes of operation(barkhausen),coupled with
unfortunate geometry in wiring might cause harmful interference.
