  • Guests: 77
projection TV flyback.
haxor5354
Fri Jan 01 2010, 05:46AM Print
I was lucky to find a big rear projection tv on the street during the summer. theres 3 CRTs in it, each of them projects motion pictures in a primaty colour, red blue and green. they all share the same flyback transformer. all of the CRTs' HV line are connected to a block looking thing with 4 hv lines (1 goes to the flyback, the rest goes to the CRTs) I have no idea what that thing it is. could it be a voltage multiplier or just a simply a device to split 1 HV line into 3 HV line?
1262324789 2063 FT0 123109221512
1262324789 2063 FT0 123109221530
1262324789 2063 FT0 123109221549
Bennem
Fri Jan 01 2010, 07:15AM
Bennem Registered Member #154 Joined: Sun Feb 12 2006, 04:28PM
Hi Haxor5354,
Yes, CRT projectors have a EHT 'Splitter'
that supplies the three tubes.
haxor5354
Fri Jan 01 2010, 03:38PM
all it does is to spit the voltage? no change in output voltage?
Bennem
Fri Jan 01 2010, 04:46PM
The voltage mulitplying/tripling takes place in the flyback
transformer package.
In a typical CRT projector the EHT output is about 30-35KV.
which is then split three ways to feed the final anode of each CRT.
Fri Jan 01 2010, 07:09PM
Bennem wrote ...
I have never seen a DC flyback with integrated multiplier, all that I have seen use the diode split design (some 5 windings separated by diodes) and in some types, usually those from a PC monitor, the HV is filtered with a built-in HV cap.
I wonder why don't they make the transformer with 3 wires already coming off it?
wylie
Sat Jan 02 2010, 11:34PM
wylie Registered Member #882 Joined: Sat Jul 07 2007, 04:32AM
Right? Seems like if they were trying to cut costs, 3 wires coming outta the flyback would be the cheaper option. Then again, maybe they just got a good deal on those flybacks and it was cheaper to put in the splitter.
