  • Guests: 30
Reaching (40)
ryanshow (38)
07/22 Reaching (40)
07/22 ryanshow (38)
07/23 Will (38)
Finding Voltage and Resistance Output in an Induction Transformer
techhead101
Thu Dec 03 2009, 11:54AM Print
techhead101 Registered Member #2499 Joined: Thu Dec 03 2009, 10:18AM
Hey guys,
I'm stuck, i alredy know how to find the current in an Induction transformer, # of turns on primary coil/# of turns on Secondary coil, but, is there any formulas known to calculate the Voltage output and the Resistance produced by the Induction Transformer...If so, keep it simple, im only new.
radiotech
Mon Dec 07 2009, 01:34AM
I read this several times and it seems to be a question about a current transformer (c/t). The secondary circuit is limited in voltage by the burden resistance which is the drops across the various instruments,ammeters or relays. Large c/t's can produce hazardous voltages if the secondary is accidently opened. The burden at the rated secondary current, 5 amps, for example determines the accuracy for metering. Consider the secondary a constant current source. A 200/5 c/t will produce 1 amp with 40 amps in the primary.
The voltage will range from 0 (short circuit) to 1 amp * secondary circuit external resistance. R instead of Z used for clarity.
Turkey9
Mon Dec 07 2009, 04:55AM
Are you talking about a simple transformer, such as used in power supplys? In that case the voltage is proportional to the ration of turns. 100:100 will output the same voltage as the input. 200:100 will output half the input. In this case google will help a LOT. There's a bunch of easily accessible info out there on basic transformer physics.
Dr. Slack
Mon Dec 07 2009, 06:59AM
The main qusetions for techhead101 are
1) What is an induction transformer?
and
2) What does it do / do you want it to do?
