  • Guests: 38
williamn (48)
ReddyK (57)
Birdman (31)
12/14 M.A.D. (32)
12/15 marko666 (58)
12/16 Will T (16)
UV power level measurement
Sun Nov 29 2009, 05:54PM Print
Hi all.
Interestingly, I just found at Mondomundi a small device labelled "UV Index Tester"
In theory it could be used as a way to measure the power level of an unknown UV or NUV source as it contains a calibration table.
Could also be read using nothing more than a cheap webcam sensor or even a reflectance sensor would do.
Attach to existing PCB developer and command it to scan to location, apply laser power for n seconds and read the result, then ramp up laser power and repeat.
any use? the manufacturers are Powertraveller.
regards, -A
