  • Guests: 36
Proud Mary (62)
omegalabs (39)
Plasma Lover (32)
09/16 Michael Witt (36)
09/16 AleSeg (15)
09/17 Jyardana (41)
Sub-Microsecond Pulses, Plasma Pencil
Spurious J
Fri Nov 27 2009, 06:49AM Print
Spurious J Registered Member #2367 Joined: Wed Sept 16 2009, 01:07AM
So I'm trying to build a plasma pencil, and running into difficulties with the short pulses I need to generate.
It's not hard to achieve the square wave with a 555, but between the power transistor and flyback coil, I'm having difficulties keeping the square wave anything close to square.
Ideally, what I need is:
A 1-10kHz square wave, between 1-10kV. What's a better way to accomplish this?
Sat Nov 28 2009, 06:53PM
Hello Mr Spurious,
I've held back from answering your enquiry, because I don't understand your need for straight-up square waves in this application.
After all, there are simple, working examples of plasma pencils using DC.
And had you wanted something with a sheer wavefront, you would not even have considered 555.
As for the use of LOPTs ('flybacks') how could anything with so much secondary inductance ever produce a sheer wavefront?
Anway, once you've determined the needs of your application, you'll be in a much better position to determine the needs and configuration
of the driver.
Good Luck, lad,
Stella Maru
