  • Guests: 32
Reaching (40)
ryanshow (38)
07/22 Reaching (40)
07/22 ryanshow (38)
07/23 Will (38)
Unknown tube Th2
RayeR
Thu Nov 26 2009, 12:06AM Print
RayeR Registered Member #333 Joined: Mon Mar 20 2006, 06:02PM
Hi,
I got this unknown "tube": http://rayer.ic.cz/350d/Th2.jpg. There's not much marking that gives some result, just "Th2 8.52 Switzerland". Inside is something like mica sandwich with two separate windings of resistive wire. One has 60 ohm second has 71 ohm. Nothing else. Any idea for what purpose it was made/what electronic machine used it?
Thu Nov 26 2009, 12:42AM
Hi Rayer, I'd guess it was a baretter of some kind - these were used as mains voltage droppers/regulators in AC/DC domestic radios - Stella
RayeR
Thu Nov 26 2009, 10:29PM
You mean filament current stabiliser? I know it under name "variator" but it's not this case. I have such tubes but they always has only one filament placed freely in tube on supports not wound on mica. I and some other people think it was used for measure trueRMS current. One filament will be connected to AC currnt and the second one will be sensed by ohmmeter - more RMS current cause more heating and higher resistance of second filament.
Fri Nov 27 2009, 01:24AM
Who knows, Rayer? Not me this time! But your idea sounds reasonable. It could have been used for measuring AC or RF currents in this way.
radiotech
Sun Dec 06 2009, 08:20AM
The device looks like a barretter which is a current regulator used in the telephone industry to regulate the line current
current to phone apparatus which changed as the cable resistance changed with temperature. One type used a iron resistance wire in
a hydrogen filled bulb. You might try a current around 0.05 amps
to see if it exhibits a non-linear V/I curve.
