  • Guests: 39
Lyonel Baum (77)
Mattc1886 (17)
01/09 RickR (18)
01/09 TheBoozer (58)
01/09 invader (50)
18-stage coilgun
PYLEMET-mk2
Wed Nov 25 2009, 02:36PM Print
PYLEMET-mk2 Registered Member #1513 Joined: Sat May 31 2008, 12:08PM
Hi all, I'm making a new coilgun, now 7 stages is ready, going to make ~18 stages at all. Projectile 8mm dia, 9,4g weight, speed ~53 m/s, ~13,5j. Caps 400v 390mkf
Video:
Wed Nov 25 2009, 03:38PM
Looks impressive on the video. You're obviously getting some decent velocity out of it. Are you switching with IGBTs or SCRs?
What's your overall efficiency?
-Dave
PYLEMET-mk2
Wed Nov 25 2009, 04:41PM
I'm using 40tps12 SCRs
efficiency is around 5%
Turkey9
Wed Nov 25 2009, 11:57PM
You said you're shooting for 18 stages. So when the projectile gets going nice and fast toward the later stages, how are you going to shorten the pulse? Smaller coil? Less capacitance? Higher charge voltage (probably not the best option)?
I hope you get all those stages, I've always wanted to do the same but never got around to it.
PYLEMET-mk2
Thu Nov 26 2009, 10:10AM
Smaller coil, Less capacitance. Speed would not grow too quickly, max 3m/s per stage - thats why no need to short the pulse very much
PYLEMET-mk2
Tue Dec 01 2009, 11:10AM
For this time 12 stages are ready. I'm now using another projectile, 11,4g weight. Energy 22,05j, speed 62,2 m/s
Tue Dec 01 2009, 11:55AM
You might want to use a less wide picture, barely fits here on a 2048 pixel wide screen . . . Cool project though keep up the work
Turkey9
Tue Dec 01 2009, 11:37PM
wow that's impressive! Good job! What's your efficiency now? I found that adding a little bit of a delay on the trigger for the first stages improves performance. I just added a small capacitor across the output of the photogate; more capacitance the longer the delay.
PYLEMET-mk2
Fri Dec 11 2009, 06:18PM
Ended 18 stages. Speed is about 70 m/s, energy ~28j.
919211
925355
Big photos:
Cloud
Fri Dec 11 2009, 07:45PM
Cloud Registered Member #2311 Joined: Thu Aug 20 2009, 03:07PM
whats your efficiency with the extra coils?
