  • Guests: 60
Madgyver (40)
mike0t4ever (43)
Ken M. (40)
tesla500 (39)
Fabi (32)
hatto018 (40)
10/18 seveerz (69)
10/21 ben106 (40)
10/22 803 (2025)
Oscilloscope Recommendation
Sun Nov 22 2009, 06:01AM Print
I need a scope with four channels. I need to be able to measure the voltage difference between channel 1 and 2, and channel 3 and 4. My current scope can only has the ADD and INVERT for channel 1 & 2. Any recommendations? Capturing a triggered signal would be nice, too.
MinorityCarrier
Sun Nov 22 2009, 06:30AM
Tried looking at scope-maker websites?
Dr. Slack
Sun Nov 22 2009, 07:10AM
Let the voltage on channels 1 and 2 be v1 and v2. Invert channel 2 to get -v2. Add channels 1 + (inverted 2) to get v1 + (-v2) = v1-v2. Et viola, vive la difference.
To fix the "4 channel" part of the specification, you may need google and some $$
tesla500
Sun Nov 22 2009, 08:16AM
tesla500 Registered Member #347 Joined: Sat Mar 25 2006, 08:26AM
We'll need to know a little more to make suggestions.
What's your budget?
New or used?
Analog or digital?
Bandwidth requirements?
Memory depth? (digital only)
I don't know of any portable analog scopes that can do two separate math channels like you describe, possibly some large mainframe scopes with the proper plug-in modules could do it. The cheapest way to do this may be two 2-channel analog scopes.
David
Sun Nov 22 2009, 09:09AM
You may be better of buying a couple of isolated differential probes.
These probes are allways handy,
they can be moved from 'scope to 'scope.
Differential probes can be bought or home-made.
What is the REQUIRED (not 'ideal' or 'dream') input voltages and frequencies?
Sun Nov 22 2009, 06:23PM
Registered Member #2372 Joined:
Can you put the data in excel and just math it there?
Sun Nov 22 2009, 06:31PM
Yes, I know how to use the add and invert. I need these features for both 1/2 and 3/4.
In answer to Dr. Slack, I am willing to pay some $ to get a new scope, as mine will not do this. I would like to get used to save some money; I don't care if it is analog or digital, although digital would probably allow me to save images off of a triggered response.
Any suggestions? The guy selling this one said he thought it could
Anyone familiar with this model?
mikeselectricstuff
Sun Nov 22 2009, 08:07PM
Don't recall ever having seen a scope that will do multiple math ops, even on high-end kit, so differential probes are probably the way to go.
Sun Nov 22 2009, 08:15PM
I have a Tektronix 7603, a 75MHz analog scope with two dual trace vertical amp plugins, each of which has Add and Invert buttons. So it could display two traces at once, one being 1-2, the other being 3-4.
I paid about $180 for it used. Very used, it belonged to the Ministry Of Defence and looked like it had been run over by a tank. Having said that, it worked fine and still does.
Sun Nov 22 2009, 08:27PM
Also worth noting is that the diferential probe will give you much better results than the add/invert maths, as it will have much better common mode rejection and the likes.
But if you would rather be able to use the extra channels individually, you will need a fancier scope the the tds2104, I have used one before and I can confirm that it had only one math function (which could be used for 1-2 2-1 3-4 4-3 1+2 3+4 or fft) I am not sure which scope can handle that, and I think it is somewhat rare (even if it is only a simple firmware issue) but I can say I have only seen it on the high speed scopes we have in our lab (talking 5 figures before you even start buying input cards!)
