  • Guests: 31
Reaching (40)
ryanshow (38)
07/22 Reaching (40)
07/22 ryanshow (38)
07/23 Will (38)
Does anyone have the Harbor Freight 2-stage 3 CFM vacuum pump?
jpsmith123
Sat Nov 21 2009, 09:29PM Print
If so, how do you like it?
I'm wondering, what kind of thread is that on the brass inlet fitting where it screws into the pump body? It looks like 1/4" NPT, but I can't be sure just looking at the picture.
Hon1nbo
Sun Nov 22 2009, 09:53PM
in the description it says "1/4" SAE and 1/2" Acme intake fitting with dual ports for R134A and R12/R22 systems" - and as for how it works, I also would like to know because I can get these locally and don't use vacuums very often except for Plastic Casting, so it might prove useful
jpsmith123
Mon Nov 23 2009, 06:14AM
Hello DaJJHman,
That fitting is actually a "tee" fitting - what I want to know about is the part that screws into the pump body. That's because I want to replace it with an adapter that will allow me to use standard vacuum hardware.
If it is 1/4", NPT then I suppose the inlet fitting could be replaced with a standard pipe nipple (long enough to clear the handle), which could mate with a NW-25 flanged adapter.
Right now I'm trying to decide between the Harbor Freight 3 CFM pump, and a "Viot" 3 CFM pump that's sold on ebay.
The pumps seem quite similar except that the Viot has the added feature of "gas ballast", and it claims a lower ultimate vacuum: 15 vs. 25 mtorr, IIRC.
On the other hand, one important advantage of the Harbor Freight pump is the fact that you can easily return it for a refund, if you don't like it for any reason.
Hon1nbo
Wed Jan 06 2010, 01:59PM
I got this pump over break: here
not the same model, but I've loved it so far - I'll try to get the fitting off and check the size, they appear to have the same fitting but I could be wrong
-Jimmy
