  • Guests: 47
10/21 ben106 (40)
10/22 803 (2025)
10/23 Iniaes (17)
how to protecta microcontroller from data sampling
rp181
Sat Nov 14 2009, 02:40AM Print
Hey all,
I need help in deciding what kind of circuits I could use to protect a micro-controller (Link2 Inputs will be from analogue sensors, a break wire chrono (signal for this will be easy), and B-Dot probes. B-Dot probes are magnetic field sensors, they give a voltage output. I will be using this with a railgun, which means fast current rise times, and high currents. What should I do to protect the micro controller from these inputs, incase of bad inputs?
"In single ended conversion mode, the analogue input valid conversion range is 0V to 1.2V."
Hernan
Sat Nov 14 2009, 02:48AM
Hernan Registered Member #1614 Joined: Wed Jul 30 2008, 03:08PM
hi rp181, may be you´ll need to convert the voltage to freq,then optocoupler islolating barrier to protect the digital part. a bit complicated...
regards
Hernán
Bjørn
Sat Nov 14 2009, 04:10AM
Usually the analog inputs can take voltages up to the positive rail without problems. In that case you use two ultra fast diodes, One to ground and one to the positive rail. Then add a suitable series resistor to limit the current. Also add decoupling with a low ESR capacitor so spikes does not find its way into th emicrocontroller through the power supply.
In many cases a series resistor is good enough since the microcontroller has built in diodes but when you are dealing with uncertain voltages it is a good idea to add external diodes.
rp181
Sat Nov 14 2009, 04:13AM
The voltage range specified is 0-1.2v single ended.
Would zeners be suitable for the application?
Bjørn
Sat Nov 14 2009, 06:38AM
Don't expect a zener to clip at a clearly defined voltage, they work over a range. Same with diodes but they tend to be better defined. I have a 3.6V zener protecting one of my microcontrollers and it is eats up 8-10 mA at 3.3V.
Is 0-1.2 V the valid conversion voltage range or the maximum range that does not cause damage? All my microcontrollers can go outside the valid conversion range without problems, they will just not return the correct value. Do you have a link to the datasheet?
rp181
Sat Nov 14 2009, 03:07PM
The board:
The controller:
The 1.2v is the valid conversion range.
Bjørn
Sat Nov 14 2009, 03:58PM
The valid conversion range is 0 - 1.2 V because it has a 1.2 V reference voltage. The power supply to the ADC is AVDD which is 1.8 V. So the internal protection diodes will not come into play until you reach 1.8 V + 0.3 V drop over the diodes. So as long as you stay below 2.1 V you will be fine.
If you have access to AVDD you can connect the diode to that. If not you can connect several ultra fast diodes in series to get the required voltage drop.
There are also many other methods, like using an op amp buffer, a linear optocoupler and so on.
rp181
Sat Nov 14 2009, 04:24PM
thanks for the help. I think I will go with a linear optocoupler with some diodes.
Avalanche
Sat Nov 14 2009, 05:21PM
The HCPL7840 is a nice chip, has an internal gain of 8. I use it all the time!
rp181
Sat Nov 14 2009, 05:50PM
thanks for the suggestion, it looks great, and the output is limited by VDD.
