  • Guests: 48
Madgyver (40)
mike0t4ever (43)
Ken M. (40)
tesla500 (39)
Fabi (32)
hatto018 (40)
10/18 seveerz (69)
10/21 ben106 (40)
10/22 803 (2025)
Question, How to make the Z axis accelerometer on a wafer?
Electroholic
Sat Nov 07 2009, 05:29PM Print
I mean, I get the x and y, but how to does one make a an accelerometer for the axis normal to the wafer? variable plate capacitor?
In datasheets that i found, the specs for the z axis is always different.
does anyone know?
Sat Nov 07 2009, 07:06PM
Put the chip on its side? Its going to be that or buy an accelerometer specifically for that measurement.
Electroholic
Sat Nov 07 2009, 07:12PM
maybe i should have clarify it a bit.
How do they make monolithic 3DoF mems accelerometers?
MinorityCarrier
Sat Nov 07 2009, 07:35PM
Cantilever.
Conductive films are deposited on dielectrics, the films are patterned as circuits (wheatstone bridge etc.) using dry plasma etch processing, the dielectric is then removed using wet etch processing leaving the patterned conductors 'in the air' free to deflect with acceleration.
Sun Nov 08 2009, 12:57PM
hmm.. i have a broken accelerometer here, might be worth putting it under a microscope.
-A
Electroholic
Sun Nov 08 2009, 10:39PM
How about a gyro? is there a way to create a monolithic 3DoF gyro?
Vegemeister
Sat Nov 14 2009, 09:02AM
Vegemeister Registered Member #2027 Joined: Mon Mar 16 2009, 07:34AM
Three 3-axis accelerometers with some spatial separation?
Carbon_Rod
Fri Nov 20 2009, 07:14PM
There are several types of sensors that each have there own issues.
MEMs devices:
* typically electrostatics drive an oscillating mass on a spring
* mechanical deflection types are also used
* Costing less than $6 these are the most common
Gas temperature based accelerometers are usually for high end instrumentation
Optical accelerometers
Piezoelectric accelerometers
* very problematic technology, but they are still used for car alarms
Cheers,
