  • Guests: 43
Formerless coils for lightweight applications
ragnar
Tue Apr 18 2006, 12:07PM Print
Just to prove it can be done (since I can't get hold of the right gauge of aluminium wire anyway), I made a totally formerless coil:
First person to guess what the project was gets a cookie. This coil was A) wrong wire material, B) wrong dimensions, height and diameter, C) wrong shape... but I wanted to prove that the formerless coil could hold itself together. It's surprisingly durable.
Comments?
1145362062 63 FT0 Fullformer6
1145362062 63 FT0 Fullformer7
1145362062 63 FT0 Fullformer11
GimpyJoe
Tue Apr 18 2006, 12:28PM
I remember it was a wireless lifter, but I don't know what this one is for. How did you do it?
Tue Apr 18 2006, 02:28PM
They arn't all that hard, you wind a secondary like you normally would, but add a layer of waxed paper or somehting first. After a nice coating of varnish you are left with a formerless coil. Alternativley you can use the secondary in my vttc, which cuases the wire to get hot enough to expand the pvc ~1mm, so after cooling you can silde it right off amazed
This coil is to be used as the remote half of the power source in a wireless lifter...
ragnar
Tue Apr 18 2006, 03:04PM
Yup, there's any number of ways to do it. I like the "expansion by hot VTTC" method especially...
And I'm afraid there's no "is" in it... it's a bad case of "this method WAS..." for the wireless lifter... but I can't find any aluminium wire of a small enough gauge. So grr. =)
Mike
Tue Apr 18 2006, 09:50PM
Cool blackplasma, I have always wanted to try that but never had wire to waste if I messed up?
Does it actually reduce losses or anything?
I also like how your trying lots of different coils, keep it coming!
Mike
ragnar
Tue Apr 18 2006, 10:50PM
Hi Mike. Thanks, it's nice to know somebody is reading... I wish more people would reply/critique, as that's the only way it improves ^^
If the losses weren't already negligible, yes, you could say it reduces dielectric losses to the former, but one could argue that the former has been replaced with polyurethane impregnation and thus there is no net benefit. The mass benefit is more obvious and significant however.
As for the CO2 lasercut former, the goal of that is a very high Q resonator capable of taking huge powers. Has anybody even seen it?
Mike
Tue Apr 18 2006, 10:58PM
I have seen your CO2 laser cut former resonator yes, if thats what you mean?
It looks like a good idea.
Mike
ragnar
Wed Apr 19 2006, 01:31AM
Yup, that's it... perhaps I should rename the thread (again) so people can actually understand that it's finished now... :P
Potential improvements I can see for it include:
- adding some holes to the top of each slice to facilitate the mounting of electrodes, fastening of wire, etc...
- making the slots twice as deep to better accommodate more wire,
- including some kind of primary former as part of the design.
There's gotta be some minds out there with other ideas and additions =)
