  • Guests: 29
Madgyver (40)
mike0t4ever (43)
Ken M. (40)
tesla500 (39)
Fabi (32)
hatto018 (40)
10/18 seveerz (69)
10/21 ben106 (40)
10/22 803 (2025)
Spam Free Search for Data Sheets
IntraWinding
Wed Nov 04 2009, 08:56AM Print
Searching for data sheets with Google? rolleyes
Getting a ton of hard to shift spam, including pages that
want to charge for data sheets available elsewhere for free? angry
Then you need this funky custom Google search from some chap called Igor: cheesey
Seems to work! shades
Wed Nov 04 2009, 10:04AM
No it doesn't: Link2
I still get alldatasheet.com and so on. ONSemi's own copy of the MC34063 datasheet doesn't appear until the second page. frown
I class alldatasheet and the like as spam, because they collect datasheets, bid themselves up above the manufacturer's own site in the Google rankings, and then make you look at ads to get your datasheet.
Wed Nov 04 2009, 12:36PM
I always use DatasheetCatalog.com. Never had problems with spam and such, but the selection is a bit small at times.
Jrz126
Wed Nov 04 2009, 01:24PM
I always search for pdf file types. Cuts down on the spam quite a bit.
"(part #) filetype:pdf"
IntraWinding
Wed Nov 04 2009, 03:19PM
Sorry it wasn't as good as I thought.
Apparently it works by including a list of sites to block so if anyone knows how to set up one of these custom Google searches it should be a case of just adding the offenders to the block list that that one already uses.
This describes the custom search and below is the list of blocked sites at the time:
hobid.cn
rf-china.com
netcomponents.com
szchip.com
xjdz-ic.com
photk.com
amsemi.com
adgic.com
24-trade.com
loadparts.com
ihs.com
partminer.com
usbid.com
canics.com
ic-town.com
hkinventory.com
nteparts.com
ic-asap.com
nowcomponents.com
com.cn
dzsc.com
dz37.com.cn
batescomponents.com
westchip.com
digchip.com
bizrate.com
Avalanche
Wed Nov 04 2009, 06:31PM
just lately I've started going directly to datasheetcatalog.com to do datasheet searches, rather than using google like I used to. I find 90% of what I need is on there. If the component cannot be found on that site, then a good solution is to hook it across 2 phases - so that the lack of datasheet is no longer a problem!
quicksilver
Wed Nov 04 2009, 07:27PM
I've used the "NTE Quick Cross" software (free from NTE) - Pretty large database: it's very fast simplistic but it's just what's needed if you only want fast substitution and stats.
doctor electrons
Wed Nov 04 2009, 10:30PM
I don't know if anyone else does this, but i get everything i have needed from either Digikey or Allied electronics.
If you know your part # Allied references their # as well as manufacturers #. Both sites have the data sheets or a link
to the manufacturers site with data sheet. So far so good where i am concerned.
Thu Nov 05 2009, 11:00AM
quicksilver wrote ...
Presumably the catch is that it crosses your part to the NTE equivalent in the hope that you'll buy it. NTE components are generally junk.
Dr. Slack
Thu Nov 05 2009, 02:11PM
RS Components (Link2) used to force you to login to see their datasheets, but now they are all available without registration. They have a huge range of parts (but probably still a sub-set of DigiKey's)
