  • Guests: 31
Madgyver (40)
mike0t4ever (43)
Ken M. (40)
tesla500 (39)
Fabi (32)
hatto018 (40)
10/18 seveerz (69)
10/21 ben106 (40)
10/22 803 (2025)
Contraptor: open source mechanical prototyping method
aonomus
Sun Oct 25 2009, 06:10PM Print
So I stumbled across this yesterday, and it seemed quite interesting: Link2
Essentially its a mechano set on steroids, with CNC prototyping in mind (but I can see other things being built). It is based off of pegboard hole spacing, standard angle aluminum, square aluminum stock, and some (not so standard) UHMWPE channel for sliding elements. Everything else is based off of machines screws and nuts, all from the hardware store.
The main lacking area I can see is the leadscrew area with a +/- 1/32" error, although people have tried other, higher quality leadscrews (Link2
Perhaps someone could make a good TC secondary winding rig and crank out a ton of cheap secondaries?
What else do you think could be made with this stuff?
3l3ctrici7y
Sun Oct 25 2009, 11:35PM
3l3ctrici7y Registered Member #1806 Joined: Sun Nov 09 2008, 04:58AM
A pick and place machine for pcb assembly.
If one gets really gung-ho, one could make it bigger, and badder so that it
takes very little human intervention; it would have every part it needs in a suitable magazine, apply solder paste and epoxy as necessary, place components, and then feed it off to the reflow oven.
That's a cool link, thanks for sharing :)
doctor electrons
Mon Oct 26 2009, 12:56AM
Agreed! Very cool link!
Thank you for sharing this, there is surely a use here for someone!
Good information.
aonomus
Mon Oct 26 2009, 01:15AM
Would be useful for CNCing larger objects, custom mounting brackets, etc. Other mechanical jigs seem like they could be prototyped pretty darn quickly if you need it.
Probably plotters, laser etchers, hot wire cutters or foam lathes seem like easy things to do with this.
