  • Guests: 47
Madgyver (40)
mike0t4ever (43)
Ken M. (40)
tesla500 (39)
Fabi (32)
hatto018 (40)
10/18 seveerz (69)
10/21 ben106 (40)
10/22 803 (2025)
Is this an air-pressure sensor?
VulcanBB18
Tue Oct 20 2009, 08:59AM Print
VulcanBB18 Registered Member #2376 Joined: Mon Sept 21 2009, 05:13AM
Hi All,
I am working on a weather station project (using a free datalogger I got from a server-room throw-out) and I have a board that someone gave me years ago that has an unusual looking sensor on the bottom. I think at the time it was mentioned that it came from a weather balloon, but that could be incorrect or my memory being fuzzy.
The sensor in question looks like a sealed chamber or a pair of sealed chambers, I thought maybe for measuring air-pressure or maybe some other atmospheric reading?
I've attached some images of the sensor in question and the top-side of the board. The sensor I'm wondering about is the round looking metal thing with a white supporting square (ceramic by the looks). The chips on top are a set of gates, an analogue multiplexer, a counter and a timer. Any clues would be greatly appreciated! smile
cheers
Jacob
1256029142 2376 FT0 Unknown1
1256029142 2376 FT0 Unknown2
1256029142 2376 FT0 Unknown3
Tue Oct 20 2009, 09:42AM
Hi there Jacob,
it is indeed a Radiosonde. You can tell because of the two silver plated UHF inductors, which look right for the 400-406MHz weather balloon band.
I'd guess the sensor to be a capacitive steel aneroid.
I reckon the line of inductors with the crystal at one end and the UHF coils at the other will be the Local Oscillator, Frequency Multiplier Chain. The frequency of the crystal is usually written on the side of the can, from which (since you know the final output frequency to be about 403MHz) you can deduce whether the multiplier be a doubler or a tripler. Typical RF output of Radiosondes is 300mW.
This one looks fairly antique because it doesn't have Loran-C or GPS.
Tue Oct 20 2009, 05:43PM
interesting..
i have one here with a similar sensor, was planning to use it as part of my weather balloon project.
they change capacitance with altitude, so a suitable VFO connected to a PIC will work.
the slight annoyance is that this change is negligible (fractions of a pF, comparable with a tuning diode) so another circuit might be a Wheatstone bridge using a tuning diode as the opposing side.
regards, -A
Herr Zapp
Tue Oct 20 2009, 06:15PM
Vulcan -
You can see a datasheet on on one of Air, Inc's current radiosonde models at: alma.nrao.edu/development/site/.../radiosonde/ IS5A2.pdf
They still use a variable-capacitance aneroid sensor.
Regards,
Herr Zapp
Tue Oct 20 2009, 07:29PM
I heard on the radio of an absolutely amazing and extremely simple use of a weather balloon together with camera cell phone technology. Being a radio programme, there was no great technical detail, but in essence the camera cell phone was launched beneath the balloon, and so produced a continuous video stream looking earthward until the balloon exploded at about 50,000 feet. It was said that the entire curvature of the earth could be seen!
I have sourced weather balloons for £15 (about $25) and hydrogen from British Oxygen, but I don't know much about camera cell phone technology, but I bet someone else here does! smile
Tue Oct 20 2009, 07:56PM
Unfortunately lost in the heap, I have an even more primitive radiosonde box, complete with a vintage battery.
Check out these high-altitude aeronautical adventures from the same institution that brought coin-shrinking to Maker Faire:
Link2 Link2
There are some interesting comments about GPS altitude and speed limits. smile
VulcanBB18
Wed Oct 21 2009, 12:46AM
Thanks for all the responses, certainly made finding information about the device easier once I got some leads from here :)
Okay for my purposes there may be easier ways to achieve a barometric reading. Interesting to note there is a VFO on the board as mentioned by Conundrum so I guess it uses that method.
Don't really want to junk any of the board now that I know for certain it is a radiosonde!
Wed Oct 21 2009, 02:50AM
VulcanBB18 wrote ...
I have some resistive barometric sensors which work on the Wheatstone Bridge principle. I'll send you one if you'd like to contribute three dollars to 4HV. They can detect a change in altitude of a couple of feet.
VulcanBB18
Wed Oct 21 2009, 04:27AM
That's a deal Harry! :)
Wed Oct 21 2009, 04:40AM
If you'd like to send me your address in a PM, I'll post the sensor to you when I go to the Post Office on Thursday
When you send your contribution to Chris Russell, can you make sure he understands it is in fact from me - Harry
