  • Guests: 165
seveerz (69)
10/18 seveerz (69)
10/21 ben106 (40)
10/22 803 (2025)
Making a lightning detector?
kv
Fri Oct 16 2009, 07:46AM Print
kv Registered Member #809 Joined: Wed May 30 2007, 08:59AM
Hey guys, my friend and I have had an idea (Not new idea) of using a super high gain amplifier that would detect the EMP from the lightning strike, and amplify it enough to be useful, like flashing a LED.
I have a little USB interface board with 0-5V analog input, and I was thinking, of the strikes further away would generate less of m EMP, so lower voltage, so I could even use that to roughly estimate, or compare the distance of the strikes.
Has anyone used this simple method before, or any links, circuit diagrams you know of? I have tried google but they seem a bit over-complicated for what I am trying to do.
Range wouldn't need to be any more than 100km.
Fri Oct 16 2009, 08:45AM
Scott Fusare Registered Member #531 Joined: Sat Feb 17 2007, 10:51AM
Try Link2 This is Charles Wenzel's much copied detector.
Ranging of the strike is more complicated than simple peak detection, but the "stronger is closer" rule applies in general.
Note that you do not need a super high gain amplifier at all, there is plenty of energy to be detected. In the past, using a high impedance unity gain "active antenna", I have scoped lightning induced pulses on a short whip "antenna" that ranged into the 100s of mV and occasionally hit 1V in amplitude. This was from a storm that the weather service claimed was 500 km down the east coast from me.
Scott
Fri Oct 16 2009, 11:34AM
kv wrote ...
Hi there Lad! smile
Welcome to the world of Natural Radio! - the world of sometimes strange and erie radio signals produced by our Atmosphere - the world of tweeks, whistlers, spherics, and growlers.
First, can we brush talk of 'EMP' out the back yard? 'Electro-Magnetic Pulse' is a technical term for the interaction of our Earth's geo-magnetic field with Compton electrons knocked out the Air by high energy gamma in a nuclear strike. It is not just a little squirt of electromagnetism! smile
Now to take your excellent idea of a Natural Radio to pieces and show you how it can very easily be put back together in a way that will really work.
Everyone's been to see a band and heard the awful shrieking of feedback from the loudspeakers to the microphones. In fact, if you took the mike and pressed it upon against the speaker the howling would grow to such a strength it could easily burn out the whole system.
So what's this got to do with your Natural Radio Mark One? Imagine the radio signal produced by a lightning bolt as the tiniest whisper in the microphone. You amplify it one million times to play it through your speakers - and whadya get - that terrible howling! cheesey As the sound of the signal in your speaker grows, the microphone will pick up more and more of what is coming out the speaker, which will then be amplified and put out through the speakers faster and faster till we have a situation called uncontrollable oscillation.
So this is why you can't simply pick out the air with antenna, amplify it and put it through a speaker. One way or another some of the amplified signal will get back into the input, only to be amplified all over again, in a never ending loop we call "positive feedback." Your receiver will actually have become a transmitter - the founding plank of two way radio.
Friend above has directed you to Charlie Wenzel's excellent site for simple, inexpensive natural radio projects Charlie can do almost anything with a couple transistors, and is a natural teacher with a heart of gold - he regularly sends out and at his own expense - less easy to find parts for some of his circuits, and it's a shame there aren't more like him.
Good Luck with it, Lad, and do please get back to us with further questions for tips and ideas arising from your first experiments listening for whistlers and growlers. smile
Fri Oct 16 2009, 11:59AM
I should have posted this link also, Link2 Renato's website (and book) are a tremendous resource for the natural radio hobbyist. What you are endevoring to do falls into the category of sferics detection. This is an old term from early radio history, a shortened form of "atmospherics" or lightning generated impulsive noise.
Voltwad
Fri Oct 16 2009, 01:57PM
Voltwad Registered Member #1829 Joined: Sun Nov 30 2008, 01:06AM
I've often wondered if something like a Hertz detector could work here. Basically a large coil or antenna with a small (look at it under a magnifying lens) spark gap. Hertz could detect the radio from a one or two inch gap discharge from across his lab so I'd think you could detect lightning strikes from at least a few kilometers.
Fri Oct 16 2009, 02:44PM
But then you have the problem of NOT detecting the closer strikes!
An interesting factoid - Popov used a coherer as a lightning detector in the mid 1890s. Tesla, of course, did the same during his Colorado Springs period.
My personal preference would be to build "Franklin's Bells". Stunningly reckless and unsafe by modern standards but what the heck....
Fri Oct 16 2009, 05:43PM
Maybe a coil with a lot of turns connected to a high-gain amp might work? (you'd hear the strikes as pops)
but I'm not sure...
Avi
Sat Oct 17 2009, 07:01AM
works for me, make sure the coil is of about 30cm or so in diameter.
A lightning strike will appear as a wideband noise signal. If you examine the signal you can see that 1 'strike' contains several separate bursts.
Tonskulus
Sat Oct 17 2009, 02:38PM
Tonskulus Registered Member #1223 Joined: Thu Jan 10 2008, 04:32PM
Lightning stike makes highest amplitude radiowaves around 10kHz. Simple OP amp board and pretty small antenna can detect lightning strikes from 4000km range with large enough loop antenna. I have 40x40cm antenna and it detects lightning at 2000km range easily.
I suggest this:
http://members.home.nl/fkooiman/lightning/
Sat Oct 17 2009, 02:58PM
Thanks for that link Tonskulus. I like the sound card based take on the old orthogonal loops idea. Note that adding a third channel for the vertical E field would resolve the 180 deg ambiguity he shows. I suppose that's not an issue if the plan is to compare data from two different stations as he is doing.
Scott
