modify inductance meter for higher inductances
Crunchy Frog
Mon Oct 12 2009, 09:45PM
Registered Member #2422
I found this schematic on
 It says the high range is between 100uH and 5mH. If I add another range switch position with a .1uf or larger cap, could I measure larger inductances (like a tesla secondary or a mot), or is there some kind of physical limit?
Registered Member #543
Crunchy Frog wrote ... I found this schematic on   It says the high range is between 100uH and 5mH. If I add another range switch position with a .1uf or larger cap, could I measure larger inductances (like a tesla secondary or a mot), or is there some kind of physical limit? It should work well enough if you add a third range using 0.1uF.
