  • Guests: 38
Madgyver (40)
mike0t4ever (43)
Ken M. (40)
tesla500 (39)
Fabi (32)
hatto018 (40)
10/17 mike0t4ever (43)
10/17 Ken M. (40)
Old laptop as a function/signal generator?
VulcanBB18
Wed Oct 07 2009, 12:56AM Print
VulcanBB18 Registered Member #2376 Joined: Mon Sept 21 2009, 05:13AM
Hi Everyone,
Being that I've been working in IT for about 15yrs or so, I've collected a lot of bits-and-pieces including some now rather old laptops. A P75 with 64MB isn't that useful for much, but as I don't have a signal generator in my electronics collection, I wondered what extra considerations there might be apart from loading up some software to make the various required tones via the sound card?
Would it be worthwhile isolating the output somehow? Designing an amplifier for the output? I've tried searching for threads on this topic but didn't come up with much, is it even worth considering using a laptop/PC sound card output for this purpose?
All opinions gratefully received :)
cheers
Jacob
Wed Oct 07 2009, 03:53AM
Registered Member #2372 Joined:
seems like a sound card would be really slow, you can probably buy an old function generator for like 50 buck that goes up to a few MHz. If for some reason you needed a low frequency arbitrary waveform generator maybe the computer would work for that.
Bjørn
Wed Oct 07 2009, 04:28AM
See if you can find an old Soundblaster 16 with on board amplifier, I got one and it can output DC so it is brilliant for experiments. As mentioned, anything above 10-15 kHz (sinewave) is pretty hopeless with an average soundcard.
I am using this Link2 in the signal generator I am building at the moment.
VulcanBB18
Wed Oct 07 2009, 11:56PM
Thanks for the responses everyone, yes true the upper frequency limit would be pretty low, but at least I could easily create waveforms other than a square wave.
Good pickup, re: the SB16 with on-board amp, I do have one of those squirreled away, I forgot that they had a decent on-board amp, thanks!
cheers
Jacob
