  • Guests: 28
Madgyver (40)
mike0t4ever (43)
Ken M. (40)
tesla500 (39)
Fabi (32)
hatto018 (40)
10/17 mike0t4ever (43)
10/17 Ken M. (40)
Leakage current Question
Paul I
Sat Oct 03 2009, 07:39PM Print
Paul I Registered Member #2411 Joined: Sat Oct 03 2009, 05:50PM
Im looking at Mosfets specifically. My question is about how is the leakage current (Drain to source) can be found. From various data sheets, i found that a "test condition" is used (ex: vgs=100v Idss=10uA). So, they apply 100v across the mosfet (vd=100v vs=vg=0v) and measure the current?
My question is: Can you get the same leakage current by applying a short pulse across the mosfet (say 100v for 10us) and measuring the resulting current durring that pulse? Do i need to take anything else into consideration?
If im not making sense: im new here cheesey
Sat Oct 03 2009, 07:54PM
There is internal capacitance from Drain to Gate which will cause a current to flow for a short while, if the resistance from Gate to Source (your measuring system) is too high relative to Cdg x dVds/dt then the transistor will turn on for a while too.
Paul I
Mon Oct 05 2009, 01:50PM
Thank You for your reply,
First, I'd like to know how manufacturers test out the leakage current on a mosfet.
Mon Oct 05 2009, 02:24PM
wrote ...
Yes, that's exactly what they do! tongue
The pulsed method is used when a measurement with continuous current would cause the device to heat up. This is not wanted because semiconductor characteristics shift with temperature, and the manufacturer wants to specify them at 25'C.
Paul I
Mon Oct 05 2009, 03:43PM
ooooooooo suprised
Thats why,
Thank u 4 clearing that up
Dr. Slack
Mon Oct 05 2009, 06:08PM
I think Richie ought to post in this thread, just for his strap-line. smile
